Hi devs
I’m testing Martin’s new add-on, r.sentinel.import. I created an UTM21S location for my data and imported them with:
r.sentinel.import input=Downloads/S2B_MSIL1C_20171212T134159_N0206_R124_T21KZP_20171212T201017.SAFE/GRANULE/L1C_T21KZP_A004011_20171212T134158/IMG_DATA/
The problem arose when I tried to use i.color.enhance to display an RGB: I got blank screens, so I thought there must be something with the range of values.
r.univar map=T21KZP_20171212T134159_B02@PERMANENT
total null and non-null cells: 120560400
total null cells: 0
Of the non-null cells:
n: 120560400
minimum: 15
maximum: 17547
range: 17532
mean: 913.778
mean of absolute values: 913.778
standard deviation: 134.322
variance: 18042.4
variation coefficient: 14.6996 %
sum: 110165471238
that already seemed odd…
I checked the original band2 jp2 file… Values are different…
gdalinfo T21KZP_20171212T134159_B02.jp2
Driver: JP2OpenJPEG/JPEG-2000 driver based on OpenJPEG library
Files: T21KZP_20171212T134159_B02.jp2
Band 1 Block=1024x1024 Type=UInt16, ColorInterp=Gray
Min=602.000 Max=1576.000
Minimum=602.000, Maximum=1576.000, Mean=916.799, StdDev=123.509
Overviews: 5490x5490, 2745x2745, 1372x1372, 686x686
Overviews: arbitrary
Metadata:
STATISTICS_MAXIMUM=1576
STATISTICS_MEAN=916.7992
STATISTICS_MINIMUM=602
STATISTICS_STDDEV=123.50943477872
Image Structure Metadata:
COMPRESSION=JPEG2000
NBITS=15
Just to check, I imported with r.in.gdal and I’m getting exactly the same as with r.sentinel.import.
What am I doing wrong here? Why would r.in.gdal change values like that? What else needs to be set? I don’t remember to have this problem before and it happens in all bands as far as I’ve checked.
Ah, I’m using trunk r72203
Thanks in advance for any help
Vero
I tested also with 74 release branch… same result
2018-02-05 13:05 GMT+01:00 Veronica Andreo <veroandreo@gmail.com>:
Hi devs
total null cells: 0
n: 120560400
minimum: 15
maximum: 17547
range: 17532
mean: 913.778
variance: 18042.4
sum: 110165471238
Metadata:
NBITS=15
Vero
On Mon, Feb 5, 2018 at 1:14 PM, Veronica Andreo <veroandreo@gmail.com> wrote:
Hi devs
total null cells: 0
n: 120560400
minimum: 15
maximum: 17547
range: 17532
mean: 913.778
variance: 18042.4
sum: 110165471238
Metadata:
NBITS=15
Can you try again with gdalinfo -mm? This forces computation of the actual min/max values, which can differ from what is stored in the metadata (an approximation).
There can also be something wrong with i.color.enhance
Markus M
Vero
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
