[GRASS-dev] r.in.gdal -r and r.import extent=region not working properly?
Hi devs,
I just found something odd. I have a CHIRPS tif for Africa [0], but I would only need to import Ghana, so I used r.in.gdal -r. However when I visualize the data, most of it is nodata, while the full map of Africa has data all over the continent. Then, I tried also with r.import extent=region. Same result. The only thing providing what I expected to be the right result (a subset from the full map) is importing the whole map and then using r.mapcalc to clip (i need the space in my hard disk)
These are the commands and r.univar output and I attach a screenshot with the visual results:
import ghana boundaries from GADM
v.import input=GHA_adm0.shp output=GHA_adm0
g.region vector=GHA_adm0
import full map
r.in.gdal in=Desktop/chirps-v2.0.2003.01.01.tif out=chirps_full
import subsets
r.in.gdal -r in=chirps-v2.0.2003.01.01.tif out=chirps_ghana1
r.import in=chirps-v2.0.2003.01.01.tif out=chirps_ghana2 extent=region
subset imported full map
r.mapcalc expression=“chirps_ghana3 = chirps_full”
r.univar outputs
r.univar chirps_ghana1
n: 12052
minimum: -9999
maximum: 0
range: 9999
mean: -9984.07
mean of absolute values: 9984.07
standard deviation: 386.135
variance: 149100
variation coefficient: -3.86751 %
sum: -120327966
r.univar chirps_ghana2
n: 12052
minimum: -9999
maximum: 0
range: 9999
mean: -9984.07
variance: 149100
sum: -120327966
full map (region set to ghana)
r.univar chirps_full
n: 12052
minimum: -9999
maximum: 0
range: 9999
mean: -979.822
mean of absolute values: 979.822
standard deviation: 2972.74
variance: 8.83719e+06
variation coefficient: -303.396 %
sum: -11808819
subset obtained with r.mapcalc
r.univar chirps_ghana3
n: 12052
minimum: -9999
maximum: 0
range: 9999
mean: -979.822
sum: -11808819
What am I doing wrong here? I appreciate any hint :slight_smile:
I use grass trunk r72618
Vero
[0] ftp://ftp.chg.ucsb.edu/pub/org/chg/products/CHIRPS-2.0/africa_daily/tifs/p05/
(attachments)
On Sun, Apr 15, 2018 at 8:48 PM, Veronica Andreo <veroandreo@gmail.com> wrote:
Hi devs,
the visual results:
# import ghana boundaries from GADM
# import full map
# import subsets
... here r.null is missing, like
r.null chirps_whatever setnull=-9999
# check with
r.univar -e chirps_whatever
# subset imported full map
r.mapcalc expression="chirps_ghana3 = chirps_full"
### r.univar outputs
n: 12052
minimum: -9999
                     ^-- this is the hint that r.null is needed
In my test I then got
r.univar -e chirps_v2_0_2017_01_09
100%
total null and non-null cells: 2400000
total null cells: 1181279
Of the non-null cells:
n: 1218721
minimum: 0
maximum: 195.447
range: 195.447
mean: 1.41408
mean of absolute values: 1.41408
standard deviation: 5.044
variance: 25.4419
variation coefficient: 356.698 %
sum: 1723369.67863694
1st quartile: 0
median (odd number of cells): 0
3rd quartile: 0
90th percentile: 3.99494
which looks AFAIK reasonable (also graphically)
HTH
markusN
Hi devs,
trying harder I can reproduce the issue (of course not NULL related).
So, I have no clue right now why it behaves differently.
markusN
Hi devs,
fixed in trunk r72620 and relbr74 r72621. That was a rather serious bug in r.in.gdal -r, therefore IMHO a new GRASS 7.4 release should go out asap.
Markus M
markusN
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
2018-04-16 11:32 GMT+02:00 Markus Metz <markus.metz.giswork@gmail.com>:
good timing, we are close to RC1 [1]. Ma
[1] https://trac.osgeo.org/grass/milestone/7.4.1
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
On Mon, Apr 16, 2018 at 11:35 AM, Martin Landa <landa.martin@gmail.com> wrote:
Mabe a new bugfix release for 7.2 should also go out.
Markus M
Martin Landa
* Markus Neteler <neteler@osgeo.org> [2018-04-15 22:49:09 +0200]:
Hi devs,
no intention to add noise. There is something weird, here too.
# first things first
grass -c /geo/geodata/examples/chirps-v2.0.2018.01.01.tif /geo/grassdb/onsight/chirps
# importing the whole map looks visually ok
r.in.gdal input=/geo/geodata/examples/chirps-v2.0.2018.01.01.tif output=chirps_v2
# then, using the following box coordinates for Ghana from
# https://en.wikipedia.org/wiki/User%3AThe_Anome/country_bounding_boxes
g.region w=-4.000 e=4.733 n=20.000 s=11.167 -p
# to draw the box on-display
v.in.region output=ghana_box
# and doing a partial import
r.in.gdal -r input=/geo/geodata/examples/chirps-v2.0.2018.01.01.tif output=chirps_v2_subset
Regardless whether the box figures are not correct, while the imported
portion is, indeed, a box fraction of the whole map, it isn't, visually
the "right" part. It appears as a part from the coast has been imported.
I am double-checking the steps I followed, I always get the same.
Nikos
(attachments)
On Mon, Apr 16, 2018 at 12:28 PM, Nikos Alexandris <nik@nikosalexandris.net> wrote:
Hi devs,
first things first
https://en.wikipedia.org/wiki/User%3aThe_Anome/country_bounding_boxes
This bbox is north of Ghana, not Ghana.
portion is, indeed, a box fraction of the whole map, it isn’t, visually
the “right” part. It appears as a part from the coast has been imported.
Apparently you did not update your local copy of trunk or relbr74, see my previous post.
Markus M
* Markus Metz <markus.metz.giswork@gmail.com> [2018-04-16 14:00:24 +0200]:
wrote:
Hi devs,
would
visualize
all
Same
result (a
output=chirps_v2
previous post.
Markus M
Early test performed with GRASS 7.5.svn (2018), libgis Revision: 72327,
libgis Date: 2018-03-06 12:12:44 +0100 (Tue, 06 Mar 2018).
Comfirmed, buggy behaviour is away using latest trunk.
Nikos
On Mon, Apr 16, 2018 at 11:39 AM, Markus Metz
wrote:
> in
Does the bug(fix) affect all imports made with -r or only some under
"special" (whatever that is) conditions?
markusN
wrote:
in
“special” (whatever that is) conditions?
this affects only r.in.gdal, and only in G7.4+. G7.2 is not affected because there is no -r flag for r.in.gdal.
Markus M
markusN
> in
Why 7.2? I thought is is not affected...?
markusN
in
Why 7.2? I thought is is not affected…?
You are right, this affects only r.in.gdal, and only in G7.4+. G7.2 is not affected because there is no -r flag for r.in.gdal (see my previous post).
Markus M
markusN
Dear Markus,
Thanks much for such a quick fix!!! Awesome! :slight_smile:
Vero
Hi devs,
Markus M
markusN
