[GRASS-dev] r.in.wcs, r.soillossbare: Added my first addons, issues with g.extension
Hi everybody,
I just wanted to tell you that uploaded my first two addons for G7:
- r.in.wcs : Import data for region from WCS-server
- r.soillossbare: Calculate soilloss for bare soil according to
Neteler & Mitasova, 2008 [1]
Well, I'm open to read your feedback and learn from it. I know that it
is not yet real GRASS 7 code as I wanted to maintain some
G6-compatibility. Maybe I should rewrite everything using pygrass.
Generally it seems to install and work. Surely there are still some
issues to solve. The first comes already during install:
Fetching <r.in.wcs> from GRASS-Addons SVN (be patient)...
Compiling...
/bin/sh: 1: cannot create /usr/local/grass-7.0.0svn/locale/s
criptstrings/r.in.wcs_to_translate.c: Directory nonexistent
sed: couldn't flush stdout: Datenübergabe unterbrochen
(broken pipe)
make: [/usr/local/grass-7.0.0svn/locale/scriptstrings/r.in.w
cs_to_translate.c] Fehler 2 (ignoriert)
Installing...
Updating metadata file...
WARNING: No metadata available
Installation of <r.in.wcs> successfully finished
Why does g.extension try to write to /usr/local , although I just want
to install for current user? Also, the minimal html doc has some
encoding problem. I have created it just with --html-description flag.
Thank you in advance for any hint.
Martin
sources:
[1] Markus Neteler and Helena Mitasova, 2008,
Open Source GIS: A GRASS GIS Approach. Third Edition.
Martin Zbinden
Riedacker 523
3154 Rüschegg Heubach
+41 78 628 28 82
Hi Martin,
On Fri, Jul 25, 2014 at 10:50 AM, Martin Zbinden
<martin.zbinden@gmail.com> wrote:
Hi everybody,
issues to solve.
Congrats for the submission to SVN!
Compiling...
(broken pipe)
Installing...
I have no such issues on my Fedora box:
GRASS 7.0.0svn (europe_laea):~ > g.extension r.in.wcs
Compiling...
Installing...
GRASS 7.0.0svn (europe_laea):~ > g.extension r.soillossbare
Fetching <r.soillossbare> from GRASS-Addons SVN (be patient)...
Compiling...
Installing...
Installation of <r.soillossbare> successfully finished
I have no idea, which OS are you using?
It needs to be generated differently.
http://trac.osgeo.org/grass/wiki/Submitting/Docs#ModuleManualPages
You may just study the structure of an existing HTML page.
Best
Martin
sources:
Martin Zbinden
Riedacker 523
+41 78 628 28 82
grass-dev mailing list
grass-dev@lists.osgeo.org
