I tried to get in EOX' cloudless Sentinel-2 cover but got a projection
matching error (same in trunk) due to different representations:
# nc_spm_08_grass7
g.region raster=elevation -p
r.in.wms url="https://tiles.maps.eox.at/wms?" layers=s2cloudless
output=sentinel2 format=png
Downloading data from WMS server...
Reprojecting raster...
Importing raster map into GRASS...
ERROR: Projection of dataset does not appear to match current location.
Location PROJ_INFO is:
name: Lambert Conformal Conic
proj: lcc
datum: nad83
a: 6378137.0
es: 0.006694380022900787
lat_1: 36.16666666666666
lat_2: 34.33333333333334
lat_0: 33.75
lon_0: -79
x_0: 609601.22
y_0: 0
no_defs: defined
Dataset PROJ_INFO is:
ellps: grs80
proj: lcc
lat_0: 33.75
lon_0: -79
x_0: 609601.22
y_0: 0
towgs84: 0,0,0,0,0,0,0
no_defs: defined
ERROR: datum
In case of no significant differences in the projection definitions,
use the -o flag to ignore them and use current location definition.
Consider generating a new location from the input dataset using the
'location' parameter.
ERROR: r.in.gdal failed
The issue here is that the NC sample location was generated 10 years ago.
I don't recall if we have a new lookup magic in place or not... hints
are welcome on how to proceed from here.
thanks
