/usr/local/grass-7.7.svn/scripts/r.in.wms url=url=“https://tiles.maps.eox.at/wms?” output=sen2cloudless layers=s2cloudless
File “/usr/local/grass-7.7.svn/scripts/r.in.wms”, line
241, in
sys.exit(main())
227, in main
fetched_map = wms.GetMap(options, flags)
File “/usr/local/grass-7.7.svn/etc/r.in.wms/wms_base.py”,
line 212, in GetMap
self._initializeParameters(options, flags)
line 137, in _initializeParameters
self.proj_srs = decode(self.proj_srs).rstrip(‘\n’)
NameError: global name ‘decode’ is not defined
I use the module from the GUI and I get the same error as Yann in the terminal, plus:
GRASS_INFO_END(28730,1)
ERROR 4: /home/veroandreo/grassdata/nc_spm_08_grass7/user1/.tmp/localhost.localdomain/28556.4: No such file or directory
241, in
sys.exit(main())
227, in main
line 212, in GetMap
241, in
sys.exit(main())
227, in main
line 212, in GetMap
File “/home/veroandreo/software/grass7_trunk/dist.x86_64-pc-linux-gnu/gui/scripts/d.wms”, line 214, in
sys.exit(main())
File “/home/veroandreo/software/grass7_trunk/dist.x86_64-pc-linux-gnu/gui/scripts/d.wms”, line 207, in main
temp_map = wms.GetMap(options, flags)
File “/home/veroandreo/software/grass7_trunk/dist.x86_64-pc-linux-gnu/etc/r.in.wms/wms_base.py”, line 215, in GetMap
self.temp_map = self._download()
File “/home/veroandreo/software/grass7_trunk/dist.x86_64-pc-linux-gnu/etc/r.in.wms/wms_drv.py”, line 232, in _download
temp_map_dataset.SetProjection(projection)
File “/usr/lib64/python2.7/site-packages/osgeo/gdal.py”, line 1851, in SetProjection
return _gdal.Dataset_SetProjection(self, *args)
TypeError: in method ‘Dataset_SetProjection’, argument 2 of type ‘char const *’
GRASS_INFO_END(3660,1)
ERROR 4: /home/veroandreo/grassdata/latlong_wgs84/pruebas/.tmp/localhost.localdomain/3210.4: No such file or directory
using r73371
Vero
El mié., 19 sept. 2018 a las 15:27, Anna Petrášová (<kratochanna@gmail.com>) escribió:
241, in
sys.exit(main())
227, in main
line 212, in GetMap
sys.exit(main())
using r73371
Vero
241, in
sys.exit(main())
227, in main
line 212, in GetMap
sys.exit(main())
using r73371
Vero
241, in
sys.exit(main())
227, in main
line 212, in GetMap
