[GRASS-dev] r.info -g
r.info module has a lot of flags [1] which print *given* information
to stdout. From my point of view it would be better (maybe) to have
only *one* flag for this purpose, e.g.
  -g Print basic information in shell script style
What do you think about it? It should not break any scripts in CVS
tree (maybe Add-ons?). Sure, it is not a good way -- to break backward
compatibility... on the other hand, just adding new flag -g is not
also nice solution.
Best, Martin
[1]
  -r Print range only
  -s Print raster map resolution (NS-res, EW-res) only
  -t Print raster map type only
  -g Print raster map region only
Martin Landa <landa.martin@gmail.com> * http://gama.fsv.cvut.cz/~landa *
I very much agree. This the very thing I was posting about yesterday.
Michael
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Date: Sun, 3 Sep 2006 23:41:59 +0200
To: grass-dev <grass-dev@grass.itc.it>
Subject: [GRASS-dev] r.info -g
also nice solution.
Best, Martin
[1]
  -r Print range only
I also agree. Output everything in a machine readable format that isn't
visually difficult to navigate. It's only a few lines of information at
the most. However, it may be beneficial to some to have '-r' remain
separate (may break user scripts?).
Michael
phone: 480-965-6213
fax: 480-965-7671
> From: Martin Landa <landa.martin@gmail.com>
> Hi all,
> also nice solution.
> Best, Martin
> [1]
> -r Print range only
Brad Douglas <rez touchofmadness com> KB8UYR
Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
also nice solution.
We shouldn't remove existing flags, but an additional flag to print
all available information in a parsable format would be a useful
addition.
also nice solution.
addition.
Glynn's right. But I hope that in Grass 7 the flag for a *complete*,
parsable r.info output could be changed to -g anyway (since g.region,
v.univar, v.db.connect, v.category, r.univar, r.sunmask, r.in.xyz use
it already).
Should it go to Grass 7 plans WIKI?
Maciek
>information > to stdout. From my point of view it would be better
>(maybe) to have > only *one* flag for this purpose, e.g.
>backward > compatibility... on the other hand, just adding new flag
>-g is not > also nice solution.
> addition.
it already).
consistency is good.
Let's just do this in 6.3-HEAD. Adding more lines to the "r.info -g"
shouldn't be too damaging. The only problem it could cause (that I can
think of) is if someone used something like `r.info -g | tail -1` in a
script. I think that's minor enough and poorly written enough to not be
a major concern.
Hamish
