anyone has an idea why r.info prints the title in this way:
compose_line(out, "Title: %s ( %s )",
cats_ok ? cats.title : "??",
hist_ok ? Rast_get_history(&hist, HIST_TITLE) : "??");
most raster maps then show:
( elevation )
because cats.title is empty which looks pretty confusing. Is this some
legacy issue, should it be changed?
Anna
On Fri, May 13, 2016 at 9:18 AM, Anna Petrášová <kratochanna@gmail.com> wrote:
( elevation )
I can see now several C modules set the 'cats' title, but there is no
way to set it through r.support or r.category so it can't be used from
scripts unless you use ctypes. I am still unclear what's the point of
these 2 titles.
Anna
Anna
On Fri, May 13, 2016 at 3:45 PM, Anna Petrášová <kratochanna@gmail.com> wrote:
( elevation )
these 2 titles.
Maybe check the old GRASS 4 programmer's manual:
https://grass.osgeo.org/grass43/manuals/progman42.pdf
eg on page 72 is some discussion.
