[GRASS-dev] r.le.setup / r.le.trace compilation errors
hello,
errors in r.le compilation in SVN
r.le.setup
gcc -I/home/yann/tmp/grass/dist.x86_64-unknown-linux-gnu/include -g
-O2 -I/usr/include/gdal -DPACKAGE=\""grassmods"\"
-I/home/yann/tmp/grass/dist.x86_64-unknown-linux-gnu/include -o
OBJ.x86_64-unknown-linux-gnu/ask_group.o -c ask_group.c
ask_group.c:25:24: error: grass/vask.h: No such file or directory
make: *** [OBJ.x86_64-unknown-linux-gnu/ask_group.o] Error 1
root@siduxbox:/home/yann/tmp/grass/raster/r.le/r.le.setup#
r.le.trace
OBJ.x86_64-unknown-linux-gnu/main.o: In function `show_patch':
/home/yann/tmp/grass/raster/r.le/r.le.trace/main.c:169: undefined
reference to `G_yes'
/home/yann/tmp/grass/raster/r.le/r.le.trace/main.c:178: undefined
/home/yann/tmp/grass/raster/r.le/r.le.trace/main.c:209: undefined
/home/yann/tmp/grass/raster/r.le/r.le.trace/main.c:215: undefined
/home/yann/tmp/grass/raster/r.le/r.le.trace/main.c:252: undefined
OBJ.x86_64-unknown-linux-gnu/main.o: In function `main':
/home/yann/tmp/grass/raster/r.le/r.le.trace/main.c:72: undefined
reference to `R_screen_top'
/home/yann/tmp/grass/raster/r.le/r.le.trace/main.c:73: undefined
reference to `R_screen_bot'
/home/yann/tmp/grass/raster/r.le/r.le.trace/main.c:74: undefined
reference to `R_screen_left'
/home/yann/tmp/grass/raster/r.le/r.le.trace/main.c:75: undefined
reference to `R_screen_rite'
/home/yann/tmp/grass/raster/r.le/r.le.trace/main.c:88: undefined
reference to `D_new_window'
/home/yann/tmp/grass/raster/r.le/r.le.trace/main.c:89: undefined
reference to `D_set_cur_wind'
/home/yann/tmp/grass/raster/r.le/r.le.trace/main.c:90: undefined
reference to `D_show_window'
collect2: ld returned 1 exit status
Yann Chemin
International Rice Research Institute
Office: http://www.irri.org/gis
Perso: http://www.freewebs.com/ychemin
sure, you are refering to trunk, which is currently under heavy
reconstruction...
Use develbranch_6 for daily work.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
Both of these are known issues.
r.le.setup
Vask no longer exists. r.le.setup will remain unavailable until
someone decides to re-write it to work without vask.
r.le.trace
/home/yann/tmp/grass/raster/r.le/r.le.trace/main.c:169: undefined reference to `G_yes'
Terminal interaction is no longer supported.
Creation of multiple display frames is no longer supported.
r.le.trace will remain unavailable until someone decides to re-write
it to work without terminal interaction or multiple display frames.
Also currently unavailable are i.points, i.vpoints, i.ortho.photo,
i.class, d.colors, d.extract, d.measure, d.profile, d.what.rast,
d.what.vect, d.zoom, g.setproj, and probably some others.
Some of these modules are gone for good, either because they have been
replaced by equivalent functionality within the GUI, or because no-one
cares enough about them to maintain them (i.e. make them work with
7.x).
r.li is a replacement for r.le
pc
Does this mean that r.le should be left out of 7.x and only stay in 6.x branch?
2008/8/27 Paolo Cavallini <cavallini@faunalia.it>:
pc
Yann Chemin
I would say so...
pc
Yann Chemin
grass-dev mailing list
grass-dev@lists.osgeo.org
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
