[GRASS-dev] r.li lib name
Building CVS today (last build a couple weeks ago). I'm getting a liblibr_li. I remember this from quite a while ago, but I thought it was fixed (ie renamed). I could also have just forgotten about it and noticed again just now.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
The equator is so long, it could encircle the earth completely once.
It hasn't changed since:
  revision 1.2
  date: 2006/11/21 22:41:06; author: markus; state: Exp; lines: +8 -13
  Serena Pallecchi/Faunalia: various fixes; r.li lib now shared lib
I saw that. I found this - I guess I did mention it last Dec, but nothing was done:
http://grass.itc.it/pipermail/grass-dev/2006-December/028101.html
Time to hit the bug tracker, I guess. Along with that other endian issue I mentioned there.
  revision 1.2
"Those people who most want to rule people are, ipso-facto, those least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
  revision 1.2
In general, if such thing is known and easy to fix and original author
absent, why not just fixing it rather than populating bug tracker and
mailing list? Or is it complicated?
View this message in context: http://www.nabble.com/r.li-lib-name-tf4741579.html#a13561661
Sent from the Grass - Dev mailing list archive at Nabble.com.
> revision 1.2
Because different people have different ideas regarding what is or is
not a bug. None of the things mentioned in the bug tracker entry are
unambiguous bugs or have an obvious unique "solution".
