[GRASS-dev] r.los on windows question
OK. I have replicated the memory allocation changes from r.cva.
It seems to run without bad allocs now. I cannot confirm that
it no longer crashes on Windows. Someone with a Windows GRASS
setup will need to do that.
The patch also contains a fix done by Mark Lake years ago that
never made it back into r.los. It fixes a problem with calculating
cell neighbourhoods in combination with raster masks (see. pts_elim.c).
Ben
----- Original Message -----
To: "developers grass" <grass-dev@lists.osgeo.org>, "Benjamin Ducke" <benjamin.ducke@oxfordarch.co.uk>
Sent: Sunday, March 1, 2009 10:17:22 AM GMT +00:00 GMT Britain, Ireland, Portugal
Subject: Re: [GRASS-dev] r.los on windows question
Markus:
Given the extreme speed improvement of r.viewshed from addons
I consider fixing r.los a waste of time.
If it is a trivial fix, and right in front of us, we might as well do it.
It is a small cost to have a working & well tested LOS module in 6.4.0,
even if it is horribly slow.
Hamish
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
(attachments)
r.los.patch (5.31 KB)
