[GRASS-dev] r.mapcalc 32-bit ceiling
Hi Grass-dev,
I ran into an unexpected issue (to me, at least) with r.mapcalc:
I was multiplying and dividing by some pretty big scalars, and one of
those was greater than a 32-bit signed value (so >2**31). What mapcalc
did was to reduce that value to 2**31 and carry on with operations.
There was no warning, and I didn't find any information about this on
the r.mapcalc help page, so I just wanted to alert (or possibly
remind) the list that this exists and note that (as a non-developer)
it took me a while to figure out that this was a problem. If there is
an easy way to throw an error instead of silently hitting a ceiling,
or this would be important enough to put on the manual webpage, I
think it would be helpful, and certainly would have saved me a ton of
time.
Thanks, and happy Thanksgiving to those in the USA!
Andy
On Fri, Nov 25, 2011 at 4:31 AM, Andy Wickert <andrewwickert@gmail.com> wrote:
Hi Grass-dev,
those was greater than a 32-bit signed value (so >231). What mapcalc
There was no warning, and I didn’t find any information about this on
time.
I ran into the same issue when I was using integers - I solved it by converting the raster to double. But I agree with Andy: I think GRASS should throw an error when the rollover occurs, or use a dedicated value in this cell, so that one can check afterwards. Thinking about it: an error is asked for, as something went wrong.
Rainer
Andy
grass-dev mailing list
grass-dev@lists.osgeo.org
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax (F): +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer@krugs.de
Skype: RMkrug
Thanks for the tip, Rainer! I'll convert to double as a workaround.
Andy
> time.
There can be a significant performance hit for doing this. Checking
whether the result of an addition overflowed is actually more
expensive than the addition itself. Checking whether a multiplication
overflowed can be even worse (particularly if you don't have a 64-bit
integer type available).
Hm. If that's a debilitating issue, perhaps the overflow check could
be triggered by a flag (e.g., if the user thinks there may be a
problem) or (easier) some information on typing and overflow could be
placed on the man page.
Andy
On Sun, Nov 27, 2011 at 4:57 AM, Andy Wickert <andrewwickert@gmail.com> wrote:
overflowed can be even worse (particularly if you don’t have a 64-bit
Hm. If that’s a debilitating issue,
I agree. And it should actualy not happen or at least a warning should be given.
problem)
That would be the minimum - I would even opt for an environmental variable GRASS_CHECK_OVERFLOW which provides overflow checking globally for all functions which can produce an overflow. r.mapcalc would be the obvious candidate, but there are others which can produce overflow and which should be checking for overflow as well.
GRASS_CHECK_OVERFLOW could have three values:
  • unset or “NO” (default): do not check for overflow (the default as it is now)
  • “error”: check and raise an error if overflow occurs
  • “warning”: check and produce a warning if overflow occurs.
I don’t think that is enough - I solved the problem on my side by using double instead of integer, but it took me some time to figure out why my results were wrong. So: Yes, there should definitely be a warning in the manual (highlighted and in Bold so that even I would have seen it…), but the option to check and raise an error on overflow should be provided.
And as an environmental variable, it could be used by all modules.
Rainer
Andy
South Africa
Skype: RMkrug
