[GRASS-dev] r.mapcalc addition
It'd be great if someone could commit the attached addition to r.mapcalc
It basically allows one to specify the seed for random number
generation by adding a new function "erand(a,b,s)" which takes a and b
as the lower and upper limit, and s is a seed that is used to initiate
the pseudo random number generator.
This is useful in modelling and simulation so that particular
replicates can be rerun exactly.
If it needs any extra work let me know and I'll make the changes.
patched files (r.mapcalc.diff):
raster/r.mapcalc/function.c
raster/r.mapcalc/Makefile
raster/r.mapcalc/func_proto.h
raster/r.mapcalc/r.mapcalc.html
additional file with erand function code:
raster/r.mapcalc/xerand.c
-Joel
"Wish not to seem, but to be, the best."
                -- Aeschylus
(attachments)
rmapcalc.tar.gz (1.51 KB)
I consider this to be the wrong approach. At a minimum, setting the
seed should be decoupled from the generation of random numbers;
there's no reason to have what is essentially another copy of
f_rand().
Also, it's debatable whether an r.mapcalc function is the correct
mechanism for setting an operating parameter. An environment variable
might be more suitable.
Finally, even if f_erand() was the correct interface, having it call
f_rand() once the seed has been set is preferable to including a clone
of f_rand() in the body of f_erand().
f_rand().
Okay, that seems reasonable. I went the way I did because as far as I'm aware
there was no existing system in mapcalc for options e.g. -seed=2342
and at the time I altered it I was still getting to grips with GRASS.
It is probably for the same reason, that I didn't consider environment
variables too.
If I alter f_rand() to check an environment variable (GRASS_SEED or
something similar), would that be suitable for inclusion?
-Joel
                -- Aeschylus
Glynn Clements wrote:
> r.mapcalc
> b as the lower and upper limit, and s is a seed that is used to
> initiate the pseudo random number generator.
f_rand().
what if r.mapcalc's rand(a,b) fn had an optional third argument? ie the
seed. rand(a,b) would work as it currently does, but rand(a,b,seed)
would be available if you wanted it.
Hamish
> f_rand().
variables too.
That's one option, although putting it at the top-level (at the
beginning of execute() in evalute.c) is more robust. If another
function which uses the PRNG is added later, you probably want the
seed to affect everything which uses the PRNG regardless of the
evaluation order.
> > r.mapcalc
> f_rand().
That could be problematic if you have more than one call to rand(). We
don't actually specify the evaluation order (GRASS functions don't
have side effects).
If r.mapcalc used G_parser(), a seed=... option would be the obvious
choice, but it doesn't, and that can't easily be changed. An
environment variable is probably the next best thing. For scripts,
setting an environment variable is typically easier than substituting
into an r.mapcalc expression (particularly if you are reading the
expression from a file).
> the seed. rand(a,b) would work as it currently does, but
> rand(a,b,seed) would be available if you wanted it.
have side effects).
if you have more than one call to rand() and both are seeded with the
same value (GRASS_RND_SEED or whatever), won't you get the same "random"
number both times?
should the seed be read on startup in main.c, not xrand.c ..?
Hamish
> have side effects).
number both times?
I implemented a static variable in rand function, so that it will only
be read the first time rand() is called - independent of how many
rand() occurences are in the expression.
However, I'll follow Glynn's suggestion and read the seed in the
evaluate() function. This will be more robust if other functions are
implemented that call the RNG.
On this topic, would there be any call for implementing more
complicated probability distribution functions? Or is the philosophy
of mapcalc to have the simplest elements necessary?
-Joel
                -- Aeschylus
anything from the GRASS <-> R-stats interface that you think should be
in GRASS itself?
http://cran.au.r-project.org/src/contrib/Descriptions/grasper.html
http://cran.au.r-project.org/src/contrib/Descriptions/gstat.html
(grasp is developed by Landcare Research)
Hamish
> > have side effects).
> number both times?
Note that this is necessary even if rand() only occurs once in the
expression, as the function (f_rand()) gets called once per row. You
don't want the PRNG to get re-seeded at the beginning of each row :wink:
A Gaussian distribution might be useful, as you can't readily
implement that using existing r.mapcalc functions (the usual
implementation uses iteration, which r.mapcalc doesn't support).
For enhancements which might be useful to other users, I'd suggest
posting an announcement (or the code itself) to the list. If enough
people express an interest in having the functionality built in, we
can add it.
Adding new functions is quite straightforward; OTOH, we don't want to
bloat r.mapcalc with code which is unlikely to be used by anyone but
its author.
For more complex tasks, there's always R/GRASS. r.mapcalc will always
be bound by its structural limitations (row-by-row processing,
inability to define new functions, etc).
can add it.
its author.
I've attached a diff of evaluate.c and the related html files that I'm aware of.
Turns out it was alot simpler adding the functionality as a environment variable
:slight_smile:
-Joel
                -- Aeschylus
(attachments)
r.mapcalc.diff (2.36 KB)
Hi there, I was just checking the latest CVS and saw that my r.mapcalc
addition hadn't been added yet.
I was hoping someone with appropriate permissions could do so.
My dispersal simulation tool (which I hope to release properly in a
few months) requires the addition to function correctly.
Much thanks,
Joel
---------- Forwarded message ----------
Date: Oct 26, 2006 9:39 PM
Subject: Re: [GRASS-dev] r.mapcalc addition
To: Glynn Clements <glynn@gclements.plus.com>
Cc: Hamish <hamish_nospam@yahoo.com>, grass-dev@grass.itc.it
can add it.
its author.
:slight_smile:
-Joel
                -- Aeschylus
-Joel
"Unless you try to do something beyond what you have mastered, you
will never grow." -C.R. Lawton
(attachments)
Done.
