[GRASS-dev] r.mapcalc changed to use G_parser()
I have changed r.mapcalc in 7.x to use G_parser():
  $ r.mapcalc --help
  Description:
   Raster map calculator.
  Keywords:
   raster
  Usage:
   r.mapcalc [expression=string] [input=name] [--overwrite] [--verbose]
     [--quiet]
  Flags:
   --o Allow output files to overwrite existing files
   --v Verbose module output
   --q Quiet module output
  Parameters:
    expression Expression to evaluate
         input File containing expression to evaluate
Note that, as expression= is the first option, it is the default. This
means that passing an expression on the command line is compatible
with both the old and new interfaces, so long as you:
a) quote the expression, and
b) include a space before the first = sign.
E.g.:
  r.mapcalc "foo = 1"
or:
  r.mapcalc 'foo = 1'
An unquoted expression (i.e. split over multiple arguments) won't
work, nor will omitting the space before the = sign:
  $ r.mapcalc 'foo=1'
  Sorry, <foo> is not a valid parameter
If no options are given, it manufactures "input=-" (which reads from
stdin), so you can continue to use e.g.:
  r.mapcalc < file
or:
  r.mapcalc <<EOF
  foo = 1
  EOF
But unless you need compatibility with previous versions, use input=
explicitly, e.g.:
  r.mapcalc input=file
or:
  r.mapcalc input=- <<EOF
  foo = 1
  EOF
Also, it now recognises --o[verwrite] and $GRASS_OVERWRITE, so you
will get an error if you try to overwrite an existing map without one
of those.
Note that older versions don't understand --o, so if you want to write
a shell script which is compatible with both versions, and which will
overwrite existing maps, use e.g.:
  GRASS_OVERWRITE=1 r.mapcalc 'foo = 1'
Python scripts only need to work with 7.x, so you can just use --o (or
overwrite=True with grass.run_command etc).
wow!
j
2008/8/6 Glynn Clements <glynn@gclements.plus.com>:
       $ r.mapcalc --help
       Description:
       Keywords:
        raster
       Usage:
          [--quiet]
       Flags:
       Parameters:
E.g.:
       r.mapcalc "foo = 1"
or:
       r.mapcalc 'foo = 1'
       $ r.mapcalc 'foo=1'
       r.mapcalc < file
or:
       r.mapcalc <<EOF
       foo = 1
       EOF
explicitly, e.g.:
or:
       foo = 1
       EOF
of those.
grass-dev mailing list
grass-dev@lists.osgeo.org
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
