I am observing corrupted output from r.mapcalc in trunk if compiled
--with-pthread. The result is not identical to the one obtained
--without-pthread. The mapcalc expression included the functions
eval(), min(), and max(), in case that helps. Open a ticket?
Markus M
Yes.
Also, can you describe whether (and how) the behaviour is affected by:
export WORKERS=1
The WORKERS environment variable controls the maximum number of
threads used; the default value is 8.
On Thu, May 17, 2012 at 7:33 AM, Glynn Clements
Yes.
export WORKERS=1
With WORKERS=1, the r.mapcalc result is identical to pthreads
disabled, i.e. correct. Do you need more info?
Markus M
Yes.
export WORKERS=1
More info:
I think the bug is not caused by the combination of pthreads with
eval(), min(), or max(), but rather when the same raster map appears
twice in a r.mapcalc expression. A simple example would be
r.mapcalc "result = if(isnull(map1), map2, map2 + map1)"
Maybe in r.mapcalc/map.c, get_map_row()
pthread_mutex_lock(&m->mutex);
has no effect and the same file is accessed twice at the same time,
causing garbage?
Markus M
More info:
causing garbage?
I can't reproduce this.
Can you confirm that you did "make clean" before or after running
configure? Using a non-threaded r.mapcalc with a threaded libgis could
cause this problem. Running:
nm -D `which r.mapcalc` | fgrep pthread
will confirm that the actual r.mapcalc binary being used was built
with pthread support, in case you have multiple versions of r.mapcalc
and/or libgis on your system.
More info:
pthread\_mutex\_lock\(&m\->mutex\);
causing garbage?
I can't reproduce this either with the sample datasets. Maybe this
happens only with larger raster maps? The mismatch occurs with raster
maps with 400 million cells.
cause this problem.
Compiling trunk takes about 2 minutes on my test system, I don't know
pthreads, so I decided to stay safe and did make distclean before
reconfiguring and recompiling with/without pthreads. And my local copy
has no modifications in r.mapcalc or libgis.
Markus M
