While editing the operator precedence table in r.mapcalc.html, I found that
operators with higher precedence have HIGHER numbers. Shouldn't the highest
precedence have the lowest number or 1?
Huidae Cho
Huidae Cho
That's the usual convention.
> precedence have the lowest number or 1?That's the usual convention.
You mean the convention is that the higher precedence has the higher number?
Huidae Cho
> That's the usual convention.You mean the convention is that the higher precedence has the higher number?
I meant that your suggestion was the usual convention, but in
retrospect it's less clear-cut. E.g. Haskell uses higher numbers for
higher precedence:
infixr 9 .
infixl 9 !!
infixr 8 ^, ^^, **
infixl 7 *, /, `quot`, `rem`, `div`, `mod`, :%, %
infixl 6 +, -
--infixr 5 : -- this fixity declaration is hard-wired into Hugs
infixr 5 ++
infix 4 ==, /=, <, <=, >=, >, `elem`, `notElem`
infixr 3 &&
infixr 2 ||
infixl 1 >>, >>=
infixr 1 =<<
infixr 0 $, $!, `seq`
