[GRASS-dev] r.mapcalc/r.univar and 0.0/rand
I noticed that if I create DCELL raster by
$ r.mapcalc 'map=0.0'
the 'r.univar map' says the min. value is:
minimum: 0
But when I create a 0 DCELL raster using rand function:
$ r.mapcalc 'map=rand(0.0,2.0)'
the min. value reported by 'r.univar map' is different:
minimum: 7.81597e-14
Why this difference? I would expect "minimum: 0" in both cases.
Maciek
minimum: 0
Why? The probability of getting exactly 0.0 out of rand(0.0,2.0) is so
small as to be negligible.
The probability of any single value being exactly 0.0 is less than
1e-300, so you would need in the region of 1e300 values to have a
reasonable probability that one of them would be exactly 0.0.
Oops. That was dumb of me. Of course. Forgive me - it was late here
when I asked that question.
Best,
Maciek
