[GRASS-dev] r.modis.download
I have installed r.modis with the grass-addons as follow:
#install pyMODIS from git
git clone git://github.com/lucadelu/pyModis.git
cd $install_root/pyModis
python setup.py install
cd $install_root
#make grass-addons
cd $install_root/grass-addons/grass7
make MODULE_TOPDIR=$install_root/grass/
Tested pyModis in python, the library loads.
r.modis.download product=lst_terra_daily_1000 tiles=h27v08 startday=2012-01-01 folder=/home/yann/RSDATA/
it returns something very long finishing like this:
return Popen(args, **popts)
File “/usr/local/grass-7.0.svn/etc/python/grass/script/core.py”, line 56, in init
startupinfo, creationflags)
File “/usr/lib/python2.7/subprocess.py”, line 679, in init
errread, errwrite)
File “/usr/lib/python2.7/subprocess.py”, line 1129, in _execute_child
if isinstance(args, types.StringTypes):
RuntimeError: maximum recursion depth exceeded while calling a Python object
Thank you for any help,
Yann
Yann Chemin
Replying with a just discovered potential reason:
ftp site not accessible through working place wifi…
Can this generate such crash?
Can this module crash more gracefully?
Thank you,
Yann
On 6 November 2012 11:28, Yann Chemin <yann.chemin@gmail.com> wrote:
cd $install_root
#make grass-addons
errread, errwrite)
Yann
Yann Chemin
Yann Chemin
Hi Yann
2012/11/6 Yann Chemin <yann.chemin@gmail.com>:
ftp site not accessible through working place wifi...
the pyModis [0][1] version inside r.modis is quite old, I didn't
receive any feedback for more then one year that r.modis is in the
addons repository. Today I'll work to update it and test it
The error above seem related to grass/script/core.py and not to
r.modis module but I'll try after updating pyModis
Thank you,
Yann
[0] http://pymodis.fem-environment.eu/
[1] https://github.com/lucadelu/pymodis
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
Just want to confirm I am getting the same errors. I have normal access to the ftp site, so I guess that should not be a cause of this problem?
Thank you,
Yann
grass-dev mailing list
grass-dev@lists.osgeo.org
cd $install_root
#make grass-addons
errread, errwrite)
Yann
Yann Chemin
Yann Chemin
2012/11/6 Paulo van Breugel <p.vanbreugel@gmail.com>:
You are running r.modis in which OS?
could you send all the error log?
ciao
Luca
www.lucadelu.org
Hi Luca
My system info:
GRASS version: 7.0.svn
GRASS SVN Revision: 53689
GIS Library Revision: 52468 (2012-07-27)
GDAL/OGR: 1.9.2
PROJ.4: 4.7.0
GEOS: 3.3.3
Python: 2.7.3
wxPython: 2.8.12.1
Platform: Linux-3.5.0-17-generic-x86_64-with-Ubuntu-12.10-quantal
When running r.modis.import, I am getting the following error output (just copying the first few lines and the last part as the whole error message is too long):
File “/home/paulo/.grass7/addons/
scripts/r.modis.import”,
line 510, in
sys.exit(main())
File “/home/paulo/.grass7/addons/scripts/r.modis.import”,
line 478, in main
version = grass.core.version()
File “/usr/local/grass7/grass-7.0.svn/etc/python/grass/scr
ipt/core.py”, line 1332, in version
flags = ‘rge’)
ipt/core.py”, line 274, in parse_command
res = read_command(*args, **kwargs)
init
errread, errwrite)
_execute_child
a Python object
If you want the whole error message, please let me know.
Paulo
ciao
Luca
www.lucadelu.org
Hi Luca
My system info:
GDAL/OGR: 1.9.2
PROJ.4: 4.7.0
GEOS: 3.3.3
Python: 2.7.3
wxPython: 2.8.12.1
When running r.modis.import, I am getting the following error output (I
don't know all is relevant, just copying everything to be sure):
  File "/home/paulo/.grass7/addons/scripts/r.modis.import",
line 510, in <module>
    sys.exit(main())
line 478, in main
  File "/usr/local/grass7/grass-7.0.svn/etc/python/grass/scr
ipt/core.py", line 1332, in version
    flags = 'rge')
ipt/core.py", line 274, in parse_command
ipt/core.py", line 234, in read_command
    ps = pipe_command(*args, **kwargs)
ipt/core.py", line 211, in pipe_command
    return start_command(*args, **kwargs)
ipt/core.py", line 169, in start_command
    if debug_level() > 0:
ipt/core.py", line 1346, in debug_level
    _debug_level = int(gisenv().get('DEBUG', 0))
ipt/core.py", line 682, in gisenv
    s = read_command("g.gisenv", flags='n')
the error is in grass.core.version(). I try also to run it from
console and I obtain the same error.
I'm looking the code but it's a little bit confused because a lot of
module are called and I really don't understand where is the bug.
ciao
Luca
www.lucadelu.org
2012/11/6 Luca Delucchi <lucadeluge@gmail.com>:
see
http://lists.osgeo.org/pipermail/grass-dev/2012-November/060670.html
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
