On 1 November 2012 12:29, Markus Neteler <neteler@osgeo.org> wrote:
On Wed, Oct 31, 2012 at 10:33 PM, Glynn Clements
<glynn@gclements.plus.com> wrote:
> Moritz Lennert wrote:
>> > I suggest that modules should not simply be moved from addons to
>> > trunk, but that a developer has a close look at a module including
>> > testing before moving it to trunk.
>> +1, but I see Martin's point about lack of dev power. So the trade-off
>> has to be between quality of code and value added of having a
>> functionality in trunk even if the code is not perfect.
> Relegating something to add-ons is a reliable way to reduce the amount
> of developer oversight it gets. E.g. currently you can't just "make"
> the add-ons/grass7 directory (it lacks a Makefile),
Now there is.
Thanks !
> so most developers
> won't even try to compile it. If the modules were in trunk, developers
> may notice errors or warnings as part of the normal build process.
Agreed.
I also think that we need the toolbox concept rather at GUI level than
at directory level.
+1 there was an earlier discussion about using modules keywords to make
module groups...
Now there is.
r53636 fixes a couple of issues with the r.in.wms2 and v.in.wfs2
Makefiles. From the add-ons/grass7 directory, you can do e.g.:
make MODULE_TOPDIR=$GISBASE
to build everything using the include/Make/*.make files from GRASS
7 (either installed or the dist.<arch> directory).
imagery/i.vi.mpi requires mpicc. This should probably be a separate
variable, e.g. $(MPICC).
vector/v.in.redwg requires LIBREDWGLIBPATH and LIBREDWGINCPATH to have
any necessary -L/-I switches for libredwg and dwg.h.
> Now there is.
Thanks, including addons SVN in my daily compile... How could we auto-load
those additional modules in their GUI menu groups?
to be set as a configure file option?
the add-ons/grass7 directory (it lacks a Makefile), so most developers
btw, there are logs from WinGRASS AddOns packaging available online [1].
AFAIK, at present you need to edit menudata.xml.
Once it's moved into trunk, configure checks should be added. Until
then, it should just define a variable which can be overridden on the
command line.
Currently, it uses CC, which is problematic. Uusing CC=mpicc on the
command line would cause all C code to be compiled using mpicc, while
using e.g. CC=gcc on the command line would override the setting in
i.vi.mpi/Makefile.
A fundamental property of "make" is that variables set on the command
line override settings within a Makefile, so every Makefile variable
is effectively a command-line parameter with a default value.
auto-load
OK, I will see how to modify this one
command line.
i.vi.mpi/Makefile.
g.cloud.py imports pexpect (which isn't part of the standard library)
but doesn't use it. cloud_ssh.py does use pexpect for scripting "ssh".
It appears to be doing this primarily so that it can feed it a
password, which is a bad idea (use ssh-agent if you want to be able to
use ssh without having to provide a password).
Also: includes a couple of shell scripts. cloud_collect.sh deals with
GRASS and could probably be converted to Python. cloud_mail.sh relies
upon a command-line "mail" program which is not particularly portable.
imagery/i.vi.mpi:
mpicc: command not found
raster/r.agent:
make: *** No targets specified and no makefile found. Stop.
raster/r.convert:
On Sat, Nov 3, 2012 at 6:29 PM, Glynn Clements <glynn@gclements.plus.com> wrote:
general/g.cloud:
ImportError: No module named pexpect
Luca Delucchi and me will work on this.
raster/r.agent:
This is slow work in progress (the author and me). The Makefile will be
added once the module starts to become usable.
raster/r.convert:
Also: consists entirely of shell scripts.
Hamish's script for a new raster directory layout in GRASS. Likely
not happening in GRASS7, so better don't add a Makefile to avoid
a mess for "innocent" users.
