[GRASS-dev] r.neighbors help file
I noticed that the options listed in the help are based odd number up to 25. However, at least with the 6.3 cvs version, any value is accepted and in looking at the code there is not apparent reason larger values shouldn't work. I tried it and it seems to run fine and accurately with values of 31 or 35.
Am I missing something or does the help page need to be updated?
T
Trevor Wiens
twiens@interbaun.com
The significant problems that we face cannot be solved at the same
level of thinking we were at when we created them.
(Albert Einstein)
Fixed in CVS.
On Fri, 5 Oct 2007 23:23:57 +0100
Fixed in CVS.
I just checked
http://www.grass.itc.it/grass63/manuals/html63_user/r.neighbors.html
and found the following text in the options section of the help page.
Neighborhood Size: The neighborhood size specifies which cells surrounding any given cell fall into the neighborhood for that cell. The size must be an odd integer. Options are: 1, 3, 5, 7, 9, 11, 13, 15, 17, 19, 21, 23, and 25. For example,
T
Trevor Wiens
(Albert Einstein)
> Fixed in CVS.
I just checked
Yes; that's the part that I've just fixed in CVS (the description.html
file).
The online documentation is taken from the weekly builds, so it will
take up to a week before the latest change appears online.
Fixed in CVS.
I just checked
It just needs time to propagate - Glynn has changed the description.html in the source directory for that module to read:
"The neighborhood <EM>size</EM> specifies which cells surrounding any given
For example," ...
The web site is built from the CVS tree once per day (if I recall correctly), unless Markus manually runs the update script. Therefore it will take a while before the correction shows up on grass.itc.it, and then perhaps another day before it shows up mirror sites.
Apologies if I've missed your point...
Scott
