[GRASS-dev] r.neighbors help file
----- Original Message Follows -----
To: Trevor Wiens <twiens@interbaun.com>
Cc: grass-dev@grass.itc.it
Subject: Re: [GRASS-dev] r.neighbors help file
Date: Sat, 6 Oct 2007 01:19:52 +0100
Trevor Wiens wrote:
> > > I noticed that the options listed in the help are
> > > based odd number up to 25. However, at least with
> > > the 6.3 cvs version, any value is accepted and in
> > > looking at the code there is not apparent reason
larger values shouldn't work. I tried it and it seems to
> > > run fine and accurately with values of 31 or 35.
> > > Am I missing something or does the help page need to
> > be updated?
> > Fixed in CVS.
> I just checked
http://www.grass.itc.it/grass63/manuals/html63_user/r.neighbors.html
> and found the following text in the options section of
> the help page.
> Neighborhood Size: The neighborhood size specifies which
> cells surrounding any given cell fall into the
> neighborhood for that cell. The size must be an odd
> integer. Options are: 1, 3, 5, 7, 9, 11, 13, 15, 17, 19,
21, 23, and 25. For example,
Yes; that's the part that I've just fixed in CVS (the
description.html file).
The online documentation is taken from the weekly builds,
so it will take up to a week before the latest change
appears online.
Sorry Glynn, just my ignorance showing again.
Thanks for fixing it.
T
Trevor Wiens
