[GRASS-dev] r.out.gdal -f flag clarification
I trying to decipher the meaning of the description of the r.out.gdal –f flag. Currently, it reads:
“Force raster export also if data loss may occur”
I take it it should read “Force raster export (note: data loss may occur)”
Eric Patton
Technologist, Geo-Spatial Data Services
Natural Resources Canada
Geological Survey of Canada (Atlantic)
Bedford Institute of Oceanography
1 Challenger Drive (P.O. Box 106)
Dartmouth, Nova Scotia, B2Y 4A2
Telephone: (902) 426-7732
Facsimile: (902) 426-4104
Email: epatton@nrcan.gc.ca
Patton, Eric wrote:
The long description would be that the -f flag does not have any effect if no data loss occurs. Only if the export settings would result in actual data loss, the -f flag has an effect and allows for the creation of a raster that is not an exact (as exact as possible given the chosen export format) representation of the raster map to be exported using the current computational region. Without the -f flag, if any of the tests is not passed, an error message is issued describing the problem and the module exits without exporting. The -f flag allows to export a raster even if some of the tests are not passed and warnings are issued instead of errors.
That sounds a bit like the -f flag would cause the module to export a raster somehow differently than without the -f flag which is not the case, the -f flag only overrides tests for data loss. IOW, if a raster could only be exported with the -f flag set, data loss will have occurred, not may have occurred.
The idea was to run r.out.gdal first without the -f flag, if it complains, change export settings or override with -f flag.
I guess the documentation as well as the warning and error messages could do with some improvement/clarification?
Markus M
Markus M:
Thanks for the info. I'll update the docs a little later today.
Eric
Patton, Eric wrote:
I trying to decipher the meaning of the description of the r.out.gdal -f
"Force raster export also if data loss may occur"
I take it it should read "Force raster export (note: data loss may
occur)"
Changing "also if" to "even if" is probably sufficient.
Markus M
Done in develbranch_6 and trunk.
Eric Patton
