[GRASS-dev] r.out.gdal rewritten
Hello, everybody :slight_smile:
I have just rewritten r.out.gdal in C language, made it based on GDAL
library. I think it should replace current r.out.gdal script based on
gdal_translate executable.
It should help to avoid cyclic GRASS and GDAL dependence.
Not fully implemented, but it works. Please test it and/or add
aditional features.
Vytautas
(attachments)
r.out.gdal.tar.gz (3.56 KB)
Hi Vytautas,
it is great, thanks a lot for this!! There is small patch (not
important changes). I think it should be added to CVS as r.out.gdal2
(e.g.) for faster improvements (and testing).
Best regards, Martin
2006/10/24, Vytautas <olivership@gmail.com>:
aditional features.
Vytautas
grass-dev mailing list
grass-dev@grass.itc.it
Martin Landa <landa.martin@gmail.com> * http://gama.fsv.cvut.cz/~landa *
(attachments)
main.c.diff.gz (1.25 KB)
On Tue, October 24, 2006 09:39, Martin Landa wrote:
Hi Vytautas,
important changes).
This patch introduces a small error:
@@ -138,12 +146,8 @@
        flag_l->key = 'l';
        flag_l->description = _("list supported output formats");
- input = G_define_option();
- input->key = "input";
- input->type = TYPE_STRING;
- input->gisprompt = "old,cell,raster";
- input->description = _("Name of input raster map");
- input->required = NO;
+ input = G_define_standard_option(G_OPT_R_INPUT);
+ format->required = NO;
The last line should obviously be
:wink:
Moritz
Another question:
Any reason that the available formats are limited to
  format->options = "AAIGrid,BMP,BSB,DTED,ELAS,ENVI,FIT,GIF,GTiff,HFA,JPEG,MEM,MFF,MFF2,NITF,PAux,PNG,PNM,VRT,XPM";
When the '-l' flag prints these formats as available:
   GRASS (ro): GRASS Database Rasters (5.7+)
   VRT (rw+): Virtual Raster
   GTiff (rw+): GeoTIFF
   NITF (rw+): National Imagery Transmission Format
   HFA (rw+): Erdas Imagine Images (.img)
   SAR_CEOS (ro): CEOS SAR Image
   CEOS (ro): CEOS Image
   ELAS (rw+): ELAS
   AIG (ro): Arc/Info Binary Grid
   AAIGrid (rw): Arc/Info ASCII Grid
   SDTS (ro): SDTS Raster
   DTED (rw): DTED Elevation Raster
   PNG (rw): Portable Network Graphics
   JPEG (rw): JPEG JFIF
   MEM (rw+): In Memory Raster
   JDEM (ro): Japanese DEM (.mem)
   GIF (rw): Graphics Interchange Format (.gif)
   ESAT (ro): Envisat Image Format
   FITS (rw+): Flexible Image Transport System
   BSB (ro): Maptech BSB Nautical Charts
   XPM (rw): X11 PixMap Format
   BMP (rw+): MS Windows Device Independent Bitmap
   AirSAR (ro): AirSAR Polarimetric Image
   RS2 (ro): RadarSat 2 XML Product
   PCIDSK (rw+): PCIDSK Database File
   PCRaster (rw): PCRaster Raster File
   ILWIS (rw+): ILWIS Raster Map
   RIK (ro): Swedish Grid RIK (.rik)
   SGI (ro): SGI Image File Format 1.0
   Leveller (ro): Leveller heightfield
   GMT (rw): GMT NetCDF Grid Format
   netCDF (rw): Network Common Data Format
   HDF4 (ro): Hierarchical Data Format Release 4
   HDF4Image (rw+): HDF4 Dataset
   PNM (rw+): Portable Pixmap Format (netpbm)
   DOQ1 (ro): USGS DOQ (Old Style)
   DOQ2 (ro): USGS DOQ (New Style)
   ENVI (rw+): ENVI .hdr Labelled
   EHdr (rw+): ESRI .hdr Labelled
   PAux (rw+): PCI .aux Labelled
   MFF (rw+): Vexcel MFF Raster
   MFF2 (rw+): Vexcel MFF2 (HKV) Raster
   FujiBAS (ro): Fuji BAS Scanner Image
   GSC (ro): GSC Geogrid
   FAST (ro): EOSAT FAST Format
   BT (rw+): VTP .bt (Binary Terrain) 1.3 Format
   LAN (ro): Erdas .LAN/.GIS
   CPG (ro): Convair PolGASP
   IDA (rw+): Image Data and Analysis
   NDF (ro): NLAPS Data Format
   DIPEx (ro): DIPEx
   ISIS2 (ro): USGS Astrogeology ISIS cube (Version 2)
   JPEG2000 (rw): JPEG-2000 part 1 (ISO/IEC 15444-1)
   L1B (ro): NOAA Polar Orbiter Level 1b Data Set
   FIT (rw): FIT Image
   RMF (rw+): Raster Matrix Format
   RST (rw+): Idrisi Raster A.1
   USGSDEM (rw): USGS Optional ASCII DEM (and CDED)
   GXF (ro): GeoSoft Grid Exchange Format
Moritz
On Tue, 24 Oct 2006, Moritz Lennert wrote:
Another question:
  format->options =
Aren't they the formats with either (rw) or (rw+), no (ro)?
Roger
   ELAS (rw+): ELAS
   DIPEx (ro): DIPEx
   FIT (rw): FIT Image
Moritz
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand@nhh.no
Another question:
The following are rw(+) and are not in the list:
Moritz
I have tried to improve C version r.out.gdal, see the attached patch.
2006/10/24, Moritz Lennert <mlennert@club.worldonline.be>:
>> Another question:
>> format->options =
Moritz
(attachments)
main.c-2.diff.gz (2.02 KB)
Martin Landa wrote:
I had to add $(DBMILIB) to the LIBES line of the Makfile, but then it runs great, including the check for available formats. I got some error messages with JPEG2000 and USGSDEM, but these seemed to be format specific and not a problem in r.out.gdal.
Moritz
>> Another question:
>> format->options =
Moritz
This will be a BIG help for many.
Michael
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Date: Tue, 24 Oct 2006 09:39:44 +0200
To: Vytautas <olivership@gmail.com>
Cc: <grass-dev@grass.itc.it>
Subject: Re: [GRASS-dev] r.out.gdal rewritten
Hi Vytautas,
aditional features.
Vytautas
I'm all for replacing the r.out.gdal script, but one problem I have with
the new C version of r.out.gdal is that it creates a temporary raster
entirely in memory and won't work with rasters larger than 2GB, of which
I have many. It would be nice if the temp raster format that is
currently the "MEM" supported the following
1) GDALCreate
2a) GDALSetRasterNoDataValue,
2b) remapping of NULL values,
3) Grass datatypes Float32, Float64, and Int32
4) Multiple Bands
5) GDALSetGeoTransform, GDALSetProjection
6) GDALSetRasterColorInterpretation ??
   (used in new r.out.gdal, but required?)
7) Files larger than 2GB
The final output format created using GDALCreateCopy may not support all
of these features depending on the target format, but we shouldn't lose
anything that is supported in GRASS when creating the temp copy,
including large files.
In the past, I have used the "EHdr" driver to support 1,2b,3, and 7.
Then I could save the Transform and Projection information elsewhere. I
seem to recall GDAL didn't fully support 5 for "EHdr" in the sense that
it wouldn't write a .prj or .wld file for newly created "EHdr" files.
The "MEM" file format has all of the requirements except #7, but it
isn't just a matter of fixing the "MEM" driver. Is there a file format
that is basically a file dump of "MEM"?
-Andy
On Tue, 2006-10-24 at 09:39 +0200, Martin Landa wrote:
Hi Vytautas,
> aditional features.
> Regards,
> Vytautas
(e.g.)
Add it as raster/r.out.gdal (the existing script is in the scripts
directory). You can name the executable r.out.gdal2 while it's being
tested then change it to r.out.gdal when it's stable, but we don't
want to have to rename the directory later.
  format->options =
don't hardcode the available formats. They will depend on the local
installation of GDAL, and what configure flags it was built with, and as
such options will vary widely. If you hard code it you impose an
artificial barrier to optional and future raster formats.
depend on "r.out.gdal -l" and examples (GTiff) instead.
Hamish
2006/10/24, Glynn Clements <glynn@gclements.plus.com>:
Martin Landa wrote:
[ship]
understand, I can do it today, if desired.
Hamish wrote:
> > format->options =
> > F2, NITF,PAux,PNG,PNM,VRT,XPM";
> and as such options will vary widely. If you hard code it you impose
> an artificial barrier to optional and future raster formats.
Vytautas wrote:
List of avaible formats in format options is now generated dynamicly.
        G_gisinit (argv[0]);
+ /* Init GDAL */
+ GDALAllRegister();
        module = G_define_module();
+ supported_formats(&gdal_formats);
        format = G_define_option();
        format->key = "format";
        format->type = TYPE_STRING;
        format->description = _("GIS format to write (case sensitive, see also -l flag)");
- format->options = "AAIGrid,BMP,BSB,DTED,ELAS,ENVI,FIT,GIF,GTiff,HFA,JPEG,MEM,MFF,MFF2,N
+ /* format->options = "AAIGrid,BMP,BSB,DTED,ELAS,ENVI,FIT,GIF,GTiff,HFA,JPEG,MEM,MFF,MFF
2,NITF,PAux,PNG,PNM,VRT,XPM"; */
+ if (gdal_formats)
+ format->options = G_store (gdal_formats);
+ else
+ G_fatal_error (_("Unknown GIS formats"));
        format->answer = "GTiff";
        if (G_parser(argc,argv)) exit(EXIT_FAILURE);
it is bad to put any non parser code before G_parser():
http://article.gmane.org/gmane.comp.gis.grass.devel/12473/
http://article.gmane.org/gmane.comp.gis.grass.devel/5224
http://article.gmane.org/gmane.comp.gis.grass.devel/12446/
http://article.gmane.org/gmane.comp.gis.grass.devel/7169
Hamish
2006/10/25, Hamish <hamish_nospam@yahoo.com>:
> Hamish wrote:
> > > format->options =
+ /* Init GDAL */
+ if (gdal_formats)
+ else
OK, you are right, on the other hand I don't know how to set
format->options dynamically based on GDAL installation without coding
before G_parser () function. So might I ask you how to solve this
problem?
Thanks!, best regards Martin
You can't.
So might I ask you how to solve this problem?
In this case, you have to use GDAL to set up the option list before
calling G_parser().
It's more accurate to say that you shouldn't call other GRASS
functions (except for G_gisinit(), G_define_*()) before calling
G_parser(). It's safe to assume that functions from third-party
libraries will never be affected by command-line options.
Note that this still precludes dynamically generating option lists
using GRASS functions. That's inevitable; if you try to use GRASS
functions to generate option lists, the values which those functions
return might be affected by command-line options, so you end up with a
chicken-and-egg problem. This will become a major issue if we add
built-in options to G_parser() which allow global settings (e.g.
environment variables or $GISRC settings) to be overridden.
entirely in memory
That's unacceptable.
If I had realised that, I wouldn't have suggested committing it to
CVS. Unfortunately, I don't know enough about GDAL to fix it myself.
To anyone else working on the new r.out.gdal: don't waste too much
time working on it until someone figures out how to fix this issue. If
it can't be done, then the module will be removed.
2006/10/25, Glynn Clements <glynn@gclements.plus.com>:
You can't.
calling G_parser().
Glynn, thanks for explanation!
If there are no objections I will commit it to CVS (raster/r.out.gdal,
module name r.out.gdal2).
Best, Martin
Sorry, I'm not reading related code, but does not many current GRASS modules
relay on loading whole raster map into ram? Not all GRASS modules scale
well :slight_smile:
IMLO better working version today than excellent version tomorrow. Talks about
replacing r.out.gdal script w C module I hear for long time, but no one does.
Now we have an option, why not use it?
My 0.02,
Maris.
> entirely in memory
Hi everyone,
Solusion!
I updated r.out.gdal code - now it does not has 2GB limit, unless target driver has or target driver does not support direct writing.
If target driver supports GDALCreate (it means direct writing) - this driver is used to output GRASS raster (no more limits).
If target driver does not supports GDALCreate - MEM driver is used to create dataset (in memory) and than destination raster is created with GDALCreateCopy.
As I mentioned, new r.out.gdal code was created with idea that GDAL should not depend on GRASS while GRASS depend on GDAL (cyclic dependency looks abnormaly).
Vytautas
I’m all for replacing the r.out.gdal script, but one problem I have with
entirely in memory
That’s unacceptable.
If I had realised that, I wouldn’t have suggested committing it to
CVS. Unfortunately, I don’t know enough about GDAL to fix it myself.
To anyone else working on the new r.out.gdal: don’t waste too much
it can’t be done, then the module will be removed.
Glynn Clements < glynn@gclements.plus.com>
(attachments)
r.out.gdal.tar.gz (3.89 KB)
