Hi devs,
I'm trying to use t.rast.out.vtk but I obtain something strange. I
think something is wrong with r.out.vtk, I maybe found two errors:
- it doesn't maintain the color of the map
- there is something doesn't work with the Z axis.
I attach two screenshot, problem.png is the paraview scene and
right.png is the right color of my map.
I also tested r.out.vtk but I obtain the same result
Thanks
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
Hi Luca,
can you please provide the command line that produces the wrong output?
Important to know is that r.out.vtk does not transform the GRASS color
table into a VTK lookup table. Therefore you do not see the colors
from GRASS in ParaView.
Best regards
Soeren
2014-11-28 14:28 GMT+01:00 Luca Delucchi <lucadeluge@gmail.com>:
Hi devs,
Thanks
ciao
Luca
www.lucadelu.org
grass-dev mailing list
grass-dev@lists.osgeo.org
On 28 November 2014 at 14:35, Sören Gebbert
<soerengebbert@googlemail.com> wrote:
Hi Luca,
Hi Soeren
r.out.vtk in=2012_01_tempmean
out=/tmp/export_temporal/2012_01_tempmean.vtk rgbmaps=2012_01_tempmean
elevation2d=elev_state_500m@PERMANENT
using the data of FOSS4g 2014 temporal workshop
ah, would it be possible to implement it? a new parameter like color?
Best regards
Soeren
ciao
Luca
www.lucadelu.org
Hi Luca,
2014-11-28 15:28 GMT+01:00 Luca Delucchi <lucadeluge@gmail.com>:
Hi Luca,
Hi Soeren
Use the "input" option to specify the raster map that should be
exported. The "rgbmaps" option expects three maps for red, green and
blue (satellite image data).
Please use the "elevation" parameter for elevation maps. The
elevation2d parameter is a number that specifies the height of the
whole map if no elevation maps was specified.
It is possible to implement. Feel free to do it.
You do not need a new parameter, since the "input" option expects one
more raster maps. Their color tables must be converted into the VTK
legacy lookup table format to visualize them in ParaView.
The "rgbmaps" option allows you to specify red, green and blue maps
that can be combined in ParaView to RGB data, hence no color table
conversion is needed here.
Best regards
Soeren
Best regards
Soeren
ciao
Luca
www.lucadelu.org
On 28 November 2014 at 16:40, Sören Gebbert
Hi Luca,
Hi Soeren
Hi Luca,
Hi Soeren
Yes, sorry this was one of the test that I did, my first test was running this
elevation=elev_state_500m@PERMANENT
It seems not, at least with the command above I cannot see the right
Best regards
Soeren
ciao
Luca
www.lucadelu.org
Hi Luca,
2014-11-28 17:16 GMT+01:00 Luca Delucchi <lucadeluge@gmail.com>:
Hi Luca,
Hi Soeren
Hi Luca,
Hi Soeren
Ok, and what exactly is the problem with the height map?
Actually, you didn't attached the png files ... at least they didn't
reached me.
However, color table conversion is currently not supported. Fell free
to implement it. I just tried to gave you a hint how to code it.
Ciao
Sören
Best regards
Soeren
ciao
Luca
www.lucadelu.org
