[GRASS-dev] r.patch input file limitation
would it be difficult to remove the hardcoded limit of input files
of the r.patch module?
thanks
What limit? It was removed in 7.0 over two years ago:
http://trac.osgeo.org/grass/changeset/23499
and appears to have been backported.
The only limit should be any OS-imposed limit on the number of open files.
On Thu, Jul 23, 2009 at 4:48 AM, Glynn Clements<glynn@gclements.plus.com> wrote:
Good.
But apparently it wasn't backported to 6.4.svn:
[neteler@localhost r.patch]$ pwd
/home/neteler/grass64_release/raster/r.patch
[neteler@localhost r.patch]$ grep MAXFILES *
nfiles.h: * Must be smaller than MAXFILES as defined in lib/gis/G.h which
nfiles.h:#define MAXFILES 200
Any objections to backport it? I want to avoid last minute breaks
but since it has been tested for 2 years...
Good.
Indeed it was.
I have now removed the cruft from the directory which essentially
confused me. All fine now.
