Hamish and I did some changes in r.profile. X monitors-related parts of documentation removed, standard options introduced and most notably, Hamish added coordinate_file
option to enable file input and make clear end checkable when standard input is used.
I’m just unsure about names coordinate_file
and profile
. Predefined name for G_OPT_M_COORDS standard option is coordinates
, so it will be good if profile
would be renamed to coordinates
. It would also improve r.profile call syntax from my point of view:
- r.profile input=… profile=
+r.profile input=… coordinates=
Moreover, profile is the output of r.profile, not the input. So, do you agree with rename of profile
to coordinates
I’m not sure about coordinate_file
versus coordinates_file
. What is more correct English here?
Note that Grass7/NewFeatures page was not updated yet.
And what about d.where and d.profile linked in r.profile manual? What they were doing at X monitors? What is their replacement in g.gui
and d.mon wx*
? Do we want for them something like what was recently implemented for d.out.file? Note that there is currently no way to run wxGUI profile tool from command line.
Vaclav
[r59031] https://trac.osgeo.org/grass/changeset/59031
[r59033] https://trac.osgeo.org/grass/changeset/59033
[r.profile] http://grass.osgeo.org/grass70/manuals/r.profile.html
[d.where] http://grass.osgeo.org/grass70/manuals/d.where.html
[d.profile] http://grass.osgeo.org/grass70/manuals/d.profile.html
[GRASS-dev] r.profile limits in Windows 7 http://lists.osgeo.org/pipermail/grass-dev/2014-February/067354.html
[GRASS-dev] d.out.file http://lists.osgeo.org/pipermail/grass-dev/2014-February/067362.html
[r59052] https://trac.osgeo.org/grass/changeset/59052
[Grass7/NewFeatures] https://trac.osgeo.org/grass/wiki/Grass7/NewFeatures
