[GRASS-dev] r.proj produces null map
on G7, I made several tentatives trying to reproject raster maps using r.proj, it doesn’t yield error but the map is completely empty (null). I made several tentatives on several maps, then also exported and reprojected with gdalwarp, to test if the problem was related to the data. Can someone reproduce this, before i open a ticket.
Thank you
Best regards,
Dr. Margherita DI LEO
Scientific / technical project officer
European Commission - DG JRC
Institute for Environment and Sustainability (IES)
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo@jrc.ec.europa.eu
Disclaimer: The views expressed are purely those of the writer and may not in any circumstance be regarded as stating an official position of the European Commission.
2015-05-18 17:16 GMT+02:00 Margherita Di Leo <diregola@gmail.com>:
r.proj, it doesn't yield error but the map is completely empty (null). I
are you sure that you have set in destination location region
correctly? See r.proj's -g flag.
Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
[forgot the list ]
On Mon, May 18, 2015 at 8:35 AM, Margherita Di Leo <diregola@gmail.com> wrote:
On Mon, May 18, 2015 at 8:18 AM, Martin Landa <landa.martin@gmail.com> wrote:
correctly? See r.proj’s -g flag.
I think so, unless I can’t see the obvious… here’s an example
r.proj -g input=accum location=GMTED2010-wgs84 mapset=res075
n=3036289.28490875 s=1327842.48956189 w=3859987.52509802 e=5240836.36134497 rows=7200 cols=7200
the region in the destination mapset is
g.region -p
projection: 99 (Lambert Azimuthal Equal Area)
zone: 0
datum: etrs89
ellipsoid: grs80
north: 3036500
south: 1327500
west: 3859750
east: 5241000
nsres: 250
ewres: 250
rows: 6836
cols: 5525
cells: 37768900
r.proj input=accum location=GMTED2010-wgs84 mapset=res075 output=acc_prova method=nearest
Input:
Cols: 7202 (7200)
Rows: 7200 (7200)
North: 49.999861 (49.999861)
South: 34.999861 (34.999861)
West: 364.995694 (4.999861)
East: 379.999861 (19.999861)
EW-res: 0.002083
NS-res: 0.002083
Output:
Cols: 5524 (5525)
Rows: 6834 (6836)
North: 3036250.000000 (3036500.000000)
South: 1327750.000000 (1327500.000000)
West: 3859750.000000 (3859750.000000)
East: 5240750.000000 (5241000.000000)
EW-res: 250.000000
NS-res: 250.000000
Allocating memory and reading input raster map…
Projecting…
r.proj complete.
r.info acc_prova
| Map: acc_prova Date: Mon May 18 08:26:37 2015 |
| Mapset: wetness-idx Login of Creator: user |
| DataBase: /home/user/GIS/grassdata |
| Title: ( acc_prova ) |
Timestamp: none
Type of Map: raster Number of Categories: 0
Data Type: DCELL
Rows: 6834
Columns: 5524
Total Cells: 37751016
Projection: Lambert Azimuthal Equal Area
N: 3036250 S: 1327750 Res: 250
E: 5240750 W: 3859750 Res: 250
Range of data: min = -nan max = -nan
Data Description:
generated by r.proj
Comments:
r.proj input=“accum” location=“GMTED2010-wgs84” mapset=“res075” outp\
ut=“acc_prova” method=“nearest” memory=300
Best regards,
Via Fermi, 2749
Best regards,
Via Fermi, 2749
