Benjamin,
I've been testing r.prominence and it is pretty nice. I forgot to copy you on a recent post to the user list with screenshots, but I assume that you received it via the list.
I've had no trouble compiling it on grass 6.4 and 6.5, but it failed with grass 7. The error is below.
cmb-MBP-2:r.prominence cmbarton$ make
test -d OBJ.i386-apple-darwin9.8.0 || mkdir -p OBJ.i386-apple-darwin9.8.0
gcc -I/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.8.0/include -I/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.8.0/include -g -O2 -I../dst/include -DPACKAGE=\""grassmods"\" -I/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.8.0/include -I/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.8.0/include -o OBJ.i386-apple-darwin9.8.0/main.o -c main.c
main.c: In function ‘main’:
main.c:72: error: storage size of ‘colors’ isn’t known
main.c:74: error: ‘DCELL’ undeclared (first use in this function)
main.c:74: error: (Each undeclared identifier is reported only once
main.c:74: error: for each function it appears in.)
main.c:74: error: ‘diskrow’ undeclared (first use in this function)
main.c:76: error: ‘outrow’ undeclared (first use in this function)
main.c:146: warning: assignment makes pointer from integer without a cast
main.c:162: error: ‘DCELL_TYPE’ undeclared (first use in this function)
make: *** [OBJ.i386-apple-darwin9.8.0/main.o] Error 1
Also, the GUI doesn't work because it tries to reference something called fpmap, instead of something like old,cell,raster, and I don't think that is a valid item.
BTW, I'll be at UCL and the IOA to give a talk on March 1. Maybe you can come down and say hi.
Best
Michael
____________________
C. Michael Barton
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
www: www.public.asu.edu/~cmbarton, http://csdc.asu.edu
