ecodiv
December 18, 2016, 6:52pm
1
Hi Steven / devs
The build status of r.randomforest shows it failed to build. From the log file this seems to be because Pandas is not installed
ERROR: Pandas not installed
make: *** [r.randomforest.tmp.html] Error 1
rm r.randomforest.tmp.html
This is also why, I guess, it is not on https://grass.osgeo.org/grass70/manuals/addons/ ?
Paulo
neteler
December 18, 2016, 7:17pm
2
On Sun, Dec 18, 2016 at 7:52 PM, Paulo van Breugel
<p.vanbreugel@gmail.com> wrote:
Hi Steven / devs
AFAIK we have no pandas installed on the osgeo6 server aka grass.osgeo.org.
Perhaps the same is true for the Windows build server.
Yes, unfortunately.
hellik
December 18, 2016, 8:12pm
3
p.vanbreugel@
> wrote:
Hi Steven / devs
grass.osgeo.org.
Yes, unfortunately.
grass-dev mailing list
grass-dev@.osgeo
what about to do some kind of a lazy import and move panda and scikit to
def main()?
It isn't needed for compiling only for running the python script.
AFAIK panda is available in osgeo4w; check needed. Scikit isn't available.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/r-randomforest-built-status-tp5300348p5300355.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
hellik
December 18, 2016, 8:17pm
4
p.vanbreugel@
> wrote:
Hi Steven / devs
log
grass.osgeo.org.
Yes, unfortunately.
grass-dev@.osgeo
def main()?
something similar like a "lazy import" is also needed for some other addons,
E.g.
https://wingrass.fsv.cvut.cz/grass73/x86_64/addons/grass-7.3.svn/logs/r.denoise.log
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/r-randomforest-built-status-tp5300348p5300357.html
neteler
December 18, 2016, 8:31pm
5
def main()?
E.g.
Is there any "best practice" example available?
hellik
December 18, 2016, 8:40pm
6
hellik@
def main()?
available.
addons,
E.g.
grass-dev@.osgeo
I've done it in this way :
https://trac.osgeo.org/grass/browser/grass-addons/grass7/vector/v.in.natura2000/v.in.natura2000.py#L151
accordingly an advice by Vaclav.
Maybe there are some other ways to do it.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/r-randomforest-built-status-tp5300348p5300359.html
<http://lists.osgeo.org/mailman/listinfo/grass-dev> ;
Here is a example for more complicated case:
https://trac.osgeo.org/grass/changeset/66482/grass-addons/grass7/vector/v.class.ml
But I don't know what is best practice, perhaps as simple solution as
possible - import in main() after parser() will work for most of the short
modules and dependencies.
Thanks for this – I have made some major changes to r.randomforest recently, including adding options for spatial cross-validation. I will move the import of pandas to a lazy import because I’m only using pandas as a convenient way of saving the cross-validation results to file.
Another question – r.randomforest is not really an appropriate name for the module anymore. I have been adding features over time, based on my own needs, but now it performs classification and regression using all of the major machine learning methods, with random forests just being one of them.
Is there a correct protocol for me to rename the script to something like r.scikit.learn, or r.ml?
Steve
Sent: Sunday, December 18, 2016 2:42 PM
To: Helmut Kudrnovsky
Cc: grass-dev@lists.osgeo.org
Subject: Re: [GRASS-dev] r.randomforest built status
On Sun, Dec 18, 2016 at 3:40 PM, Helmut Kudrnovsky <hellik@web.de > wrote:
Is there any “best practice” example available?
I’ve done it in this way :
But I don’t know what is best practice, perhaps as simple solution as possible - import in main() after parser() will work for most of the short modules and dependencies.
hellik
December 19, 2016, 6:53am
9
AFAIU also the Scikit imports should be done by a lazy import.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/r-randomforest-built-status-tp5300348p5300387.html
neteler
December 19, 2016, 7:08am
10
This is great!
Is there a correct protocol for me to rename the script to something like r.scikit.learn, or r.ml ?
IMHO the name should reflect what it does and be understandable. So, r.ml is a bit cryptic.
How about a new “family” r.learn.something? Maybe more will follow in future.
