On Oct 9, 2011, at 9:00 AM, <grass-dev-request@lists.osgeo.org> wrote:
Date: Sun, 9 Oct 2011 03:36:53 +0100
Subject: Re: [GRASS-dev] r.reclass only for int maps
To: Martin Landa <landa.martin@gmail.com>
Cc: GRASS developers list <grass-dev@lists.osgeo.org>
Message-ID: <20113.2245.545837.762166@cerise.gclements.plus.com>
Content-Type: text/plain; charset=us-asciiMartin Landa wrote:
is there any reason why r.reclass does not support FP raster maps?
The immediate reason is that the underlying functionality in libgis
doesn't support it. r.reclass merely creates the tables; it's libgis
which uses them.It would be a relatively simple matter to extend the existing
functionality to allow reclassing an integer map to an FP map (i.e.
the reclass table could contain FP values instead of integers).It would be somewhat more complex to support "reclassing" an FP map. I
use quotes because the term implies that the data consists of discrete
classes (categories). Ultimately, a reclass table is just that: a
table, i.e. an array, and you can't use floats as array indices.While there's no fundamental issue with defining a mapping whose
domain is floating-point numbers (we already do this for colour
tables), it is bound to be significantly slower than the integer case.And probably less useful.
A mapping from integers to integers can be described by a look-up
table, but a mapping from floats to either integers or floats can't be
(at least, not realistically). So you have to decide upon the nature
of the approximation: piecewise linear, cubic spline, rational spline,
or something else entirely? Or do we merge r.mapcalc into libraster so
that maps can be "reclassed" by arbitrary algebraic expressions?--
I originally raised this question with regard to discrete values maps whose values are floating point numbers, not maps in which floating point numbers represent a continuous field (e.g., as in an elevation map).
An example might be a soil map with a limited number of discrete values for K-factor.
Whether integers or floating point numbers are used, r.reclass only makes sense in the context of a map with a small number of discrete values. In that case questions about approximations do not really apply. It should just be a simple 1 to 1 mapping like we have for integers.
Are the limitations you mention a function of the data type itself or more about what the cell values represent?
Michael
____________________
C. Michael Barton
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
