[GRASS-dev] r.regression.multi failing
I am using r.regression.multi in a python script (using grass.run_command()) to compute the variance inflation factor (VIF). It runs in a loop, regressing variables one by one to all the other variables. It sometimes happen that the function fails with:
WARNING: Matrix is unsolvable
ERROR: Multiple regression failed
This causes my script to stop. However, I would like to capture this warning / error, and continue. Do you know how I can accomplish this?
Paulo
On 23 March 2016 at 14:31, Paulo van Breugel <p.vanbreugel@gmail.com> wrote:
did you try with try except ?
Paulo
ciao
Luca
www.lucadelu.org
On Wed, Mar 23, 2016 at 10:01 AM, Luca Delucchi <lucadeluge@gmail.com> wrote:
Yes, specifically:
from grass.exceptions import CalledModuleError
try:
    gscript.run_command(...)
except CalledModuleError:
Paulo
ciao
Luca
www.lucadelu.org
grass-dev mailing list
grass-dev@lists.osgeo.org
Yes, specifically:
try:
Thanks Luca and Anna, I'll have a look at except and give it a try
Paulo
ciao
Luca
www.lucadelu.org
Le Wed, 23 Mar 2016 15:55:40 +0100,
>>> Hi,
>> Hi,
>>> with:
This looks like a clear bug for me. So, even if I understand that you
need to work around it for now, could you also post a bug report with a
reproductible example ?
Moritz
with:
Not sure it is a bug? It happens when amongst the independent variables there are perfectly correlated variables. The message "WARNING: Matrix is unsolvable" therefore seems correct to me. Now this is treated as an error (ERROR: Multiple regression failed"), which I guess is the equivalent of grass.error() in a python script? Perhaps it would be possible to provide a warning instead, and give an output that can be captured, like NA for the coefficient estimates, instead of breaking of the function?
Moritz
On Wed, Mar 23, 2016 at 4:43 PM, Paulo van Breugel
with:
Yes, this warning should only occur in case of colinearity
Instead of grass.run_command(), you can use
ps = grass.start_command()
returncode = ps.wait()
returncode is zero if the module finished successfully, non-zero if an
error occurred, easy to capture in a script.
Markus M
On Wed, Mar 23, 2016 at 4:57 PM, Markus Metz <markus.metz.giswork@gmail.com>
>>>>>> Hi,
>>>>> Hi,
>>>>>> with:
provide a
OK, thanks
Markus M
On Wed, Mar 23, 2016 at 11:57 AM, Markus Metz <markus.metz.giswork@gmail.com
provide a
I don't know if the called module behavior is but or if it should be
improved somehow. Anyway, the way to deal with subprocess failure when
using GRASS Python API is to use try-except. You can also get run_command
to behave the same as in 6.4 version of the API using errors parameter:
returncode = run_command('g.region', ..., errors='status')
Other possible values are raise, ignore and exit. raise is the default and
it raises a CalledModuleError exception. Note that the exception is the
default because that's how the errors are handled in Python and it works
well also for read_command() which returns the module stdout by value.
There are different *_command() functions to conveniently cover different
cases. The most general is start_command() which is used similarly to the
underlying Popen.
Vaclav
