[GRASS-dev] r.report: build error
Hi!
Trying to build GRASS 6.3 from CVS a while ago I'm getting an error in
the r.report:
$ ~/src/straight/grass6/raster/r.report$ make
gcc -L/home/shoofi/src/straight/grass6/dist.i686-pc-linux-gnu/lib
-Wl,--export-dynamic
-Wl,-rpath-link,/home/shoofi/src/straight/grass6/dist.i686-pc-linux-gnu/lib
       -DPACKAGE=\""grassmods"\" -o
/home/shoofi/src/straight/grass6/dist.i686-pc-linux-gnu/bin/r.report
OBJ.i686-pc-linux-gnu/format.o OBJ.i686-pc-linux-gnu/header.o
OBJ.i686-pc-linux-gnu/label.o OBJ.i686-pc-linux-gnu/main.o
OBJ.i686-pc-linux-gnu/maskinfo.o OBJ.i686-pc-linux-gnu/parse.o
OBJ.i686-pc-linux-gnu/prt_report.o OBJ.i686-pc-linux-gnu/prt_unit.o
OBJ.i686-pc-linux-gnu/report.o OBJ.i686-pc-linux-gnu/stats.o
OBJ.i686-pc-linux-gnu/sums.o -lgrass_gis -lgrass_datetime -lz -lm -lz
OBJ.i686-pc-linux-gnu/prt_report.o: In function
`print_report':/home/shoofi/src/straight/grass6/raster/r.report/prt_report.c:82:
undefined reference to `_'
collect2: ld returned 1 exit status
make: ***
[/home/shoofi/src/straight/grass6/dist.i686-pc-linux-gnu/bin/r.report]
Error 1
Maciek
the r.report:
That file needs:
  #include <grass/glocale.h>
Given that most source files will ultimately require that header, it
should probably be included from gis.h rather than requiring
individual files to include it explicitly.
I've modified glocale.h to protect against multiple inclusion.
> in the r.report:
> _report.c:82: undefined reference to `_'
That file needs:
with respect to r.report, I've added glocale.h to r.report/global.h.
I removed the l12n macro from prt_report.c as AFAICT the error will
never happen due to the parser checking "options" values, so it's pretty
much a debug message in case of further development. And there's no
point burdening the translaters with never seen debug messages.
With <gis.h> and <glocale.h> in "global.h", we probably need to cleanup
the remaining doubled includes in the rest of the r.report code.
Hamish
> > in the r.report:
> That file needs:
You are right. I should move some messages to G_debug rather then
G_message.
I have done this.
Hamish
Thanks and sorry for braking the module
Jachym
Jachym Cepicky
e-mail: jachym.cepicky@centrum.cz
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
OFFICE:
Department of Geoinformation Technologies
Zemedelska 3
613 00, Brno
Czech Republick
e-mail: xcepicky@node.mendelu.cz
URL: http://mapserver.mendelu.cz
Tel.: +420 545 134 514
