with "r.resamp.stats method=sum", I'm seeing banding. Is this expected
or a case of it including points falling on the northern and eastern
bounds? so the same input cell gets counted for multiple output cells?
i.e. is it doing ( <= x <= , <= y <= ) instead of ( <= x < , <= y < ) ?
Unless the destination resolution is an integer multiple of the source
resolution, the total number of source cells used for each destination
cell will vary.
E.g. if the source resolution is 10m, and the destination resolution
is 25m, then the output cells will be based upon grids of 2x2, 2x3,
3x2 and 3x3 source cells, in equal proportions.
For the "sum" aggregate, this will have a significant effect upon the
output, as a cell computed from 3x3 source cells will contain the sum
of over twice as many values as one based upon 2x2 source cells.
The banding effect should go away if you use the -w switch. That will
cause the aggregates to use proportional fractions of each source
cell's value, rather than attributing the entire source cell to
whichever destination cell contains the source cell's centre. E.g. in
the 10m->25m case, each destination cell will use values from 2.5x2.5
source cells (i.e. it will use 2x2 values with a weight of 1, 2x1+1x2
values with a weight of 0.5, and 1x1 value with a weight of 0.25).
Using the -w switch will probably also be a lot slower.
If the banding occurs with integer scale factors, or with -w, let me
know.
> expected or a case of it including points falling on the northern
> and eastern bounds? so the same input cell gets counted for multiple
> output cells? i.e. is it doing ( <= x <= , <= y <= ) instead of ( <=
> x < , <= y < ) ?
cell will vary.
Yes, adding the -w flag did the trick now it looks good. Both slope and
curvature derivatives are perfectly clean as well.
thanks,
Hamish
ps - I've added metadata (hist/) support to r.resamp.stats & .interp,
and they now copy over the source map's color table, for all cases but
method=sum.
> > x < , <= y < ) ?
> cell will vary.
thanks,
Hamish
method=sum.
Great job Gylnn on implementing this module. I lost track of its progress
while writting up a recent proposal for a very similar topic. I can confirm
the behavior that Hamish has reported. I'll post back with a comparison
between the output from the new module, and the vector/raster hack that I had
used in the past: http://casoilresource.lawr.ucdavis.edu/drupal/node/275
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
I've added r.resamp.stats and r.resamp.interp to the GUI menus.
(Raster->Devel)
should r.resample be tagged for future removal? (same result as with:
'r.resamp.interp method=nearest' ???).
No.
r.resample uses libgis' built-in resampling, so it is guaranteed to
resample in an identical manner to other commands.
"r.resamp.interp method=nearest" performs the resampling itself, so it
could produce slightly different results due to rounding errors. The
method=nearest option was only included for completeness; if you want
nearest-neighbour resampling, r.resample is preferred.
(Raster->Devel)
No.
Honestly, this sounds confusing to me. Having NN method twice which produces
slightly different results, is hard to explain to users.
>> (Raster->Devel)
> No.
It's largely inevitable.
Even if r.resample is removed, it can (mostly) be duplicated with e.g.
"r.mapcalc dst = src", which also isn't guaranteed to produce the same
results as r.resamp.interp. Similarly for any other module which can
be made to perform a "copy" operation by some setting of its
parameters (r.mfilter with a 1x1 kernel, maybe?).
I could remove method=nearest from r.resamp.interp, but if it's ever
extended to support more advanced interpolation schemes with
parameters, the same issue could arise.
Ultimately, nearest-neighbour resampling will always have boundary
cases where the centre of an output cell falls on the boundary between
two or four input cells. In that situation, the end result will depend
upon everything which can affect the rounding error: the algorithm
used, the compiler, the compilation switches, the architecture, etc.
On Thursday 02 November 2006 17:03, Glynn Clements wrote:
> >> (Raster->Devel)
> > No.
> produces slightly different results, is hard to explain to users.
This is deviating someone from the NN issues... but:
I have been noticing some odd edge effects when using r.resamp.stats
method=mode .... i.e. i am getting a "ring" of cells with 0-value around the
actual data. Within the "ring" the results appear to match those obtained
with an alternate raster-vector-starspan-raster approach to doing the same
operation.
operation.
I wasn't making the source window large enough, with the result that
edge cells were using garbage values from outside of the source
buffer.
[r.resamp.stats was derived from r.resamp.interp. The window-setting
code was left untouched, but r.resamp.interp only needs source values
corresponding to the destination cell's centre +/- 2 source cells,
while r.resamp.stats needs source values for the whole of the
destination cell's area.]
I've committed the attached patch to CVS. Let me know if you still
encounter problems.
> the actual data. Within the "ring" the results appear to match those
> obtained with an alternate raster-vector-starspan-raster approach to
> doing the same operation.
> a graphical summary can be found here:
> http://169.237.35.250/~dylan/temp/method_mode-test.png
buffer.
encounter problems.
Glynn, others:
The latest patch looks like a winner!
I have tested out the latest r.resamp.stats, comparing the results betwee:
1. starspan aggregation and r.resamp.stats
2. r.resamp.stats and default NN resampling
I asked earlier if r.resample should be retired, the answer was
"no, keep it" as `r.resamp.interp method=nearest` isn't guaranteed to
give exactly the same result. (but `r.mapcalc new=old` will match r.resample?)
how about this one:
Should r.bilinear be tagged for retirement after GRASS 6.x?
(due to `r.resamp.interp method=bilinear`)
Just about any r.* command which has a "copy mode" (i.e. some set of
arguments which results in the output being equal to the input) will
behave like r.resample. The core of r.resample is:
for (row = 0; row < nrows; row++)
if (verbose)
G_percent (row, nrows, 2);
if (G_get_raster_row (infd, rast, row, data_type) < 0)
exit(1);
if (G_put_raster_row (outfd, rast, out_type) < 0)
exit(1);
G_mark_raster_cats (rast, ncols, &cats, data_type);
[Literal cut-and-paste from raster/r.resample/main.c]
IOW, it's a get-row/put-row loop, which relies upon the automatic
resampling performed by G_get_raster_row() etc. Any GRASS module which
reads a raster map using the current region will have the map
resampled in exactly the same way.
how about this one:
Yes.
Or replaced by a script which prints a "this module is deprecated"
warning then runs "r.resamp.interp method=bilinear ...".
> r.resample?)
if (verbose)
exit(1);
exit(1);
> how about this one:
Yes.
I think that this last option is a good migration path to a more coherent set
of resampling modules.
Thanks again Glynn for setting these up. However, I have noticed odd behavior
with r.resample.stats when the native resolution == the current resolution:
i.e. there is no difference in start/final cell size. I will start a new
thread on this topic.
Dylan Beaudette
530.754.7341
Yes.
warning added.
note r.bilinear has these two options which r.resamp.interp doesn't:
north specific input value to be assigned to the north and/or south poles for longitude-latitude grids
east specific input value to be assigned to the north and/or south poles for longitude-latitude grids
> Yes.
warning added.
Hmm. I suspect that the region enlargement will cause r.resamp.interp
will fail with "Illegal latitude for North" (or South) if you try to
resample a lat/lon map which includes either pole.
I'm starting to wonder whether we would be better off without the
latitude check, leaving it to up the user instead.
> > Yes.
> warning added.
> poles for longitude-latitude grids east specific input value to be
Would a note of caution in the man pages do the trick ?
Dylan Beaudette
530.754.7341
I think the latitude check is quite valuable. I don't see a reason to
allow incorrect results just because the user asked to do something
impossible (probably by accident).
In the case of r.resamp.interp it would be nice if the module could
silently convert affected cells to NULL instead of spitting out error
messages of course.
