I just needed r.rgb and found the script broken: must be a silly bug
but I don't see it..:
# NC
GRASS 7.1.svn (nc_spm_08_grass7): > r.rgb input=elevation
syntax error, unexpected $end, expecting VARNAME or NAME or STRING
Parse error
ERROR: parse error
ERROR: An error occurred while running r.mapcalc
Any idea?
# NC
Parse error
ERROR: parse error
Any idea?
Not all options are required but at least one of them:
https://trac.osgeo.org/grass/changeset/68072
# NC
Parse error
ERROR: parse error
Any idea?
I see, that now works:
Description:
Splits a raster map into red, green and blue maps.
Keywords:
ERROR: At least one of the following options is required: <red>,
<green> and <blue>
ok. But another error occurs (missing error handling if the output
names were selected to be identica):
red=elevation green=elevation blue=elevation
syntax error, unexpected '=', expecting '('
Parse error
ERROR: parse error
Eventually this works:
r.rgb input=elevation red=elevation.r green=elevation.g blue=elevation.b
Perhaps there is an elegant solution to catch the (user) error above?
Isn't this an issue for every module? I'm not sure if we have a general
solution (as in the previous case).
Most modules won't explicitly complain if you use the same map name
for multiple outputs, although it's anyone's guess as to what actually
ends up in the map.
I'm reasonably sure that the primary files (cellhd, cell/fcell, null,
f_{format,quant,range} etc) will be consistent, but metadata files
which are written separately (colour table, categories, history, etc)
may be from a different output.
The fact that r.rgb.py fails in this case is really just a
coincidence. It won't complain about using the same name for all
outputs, only for the case where one of the outputs matches the input.
The error arises because, in r.mapcalc, using a name on the left-hand
side of an assignment causes the name to be interpreted as a variable
rather than as a map, and the r#/g#/b# modifiers can only be applied
to maps, not variables.
# NC
Parse error
ERROR: parse error
Any idea?
Is there any reason why this should not work? According to the manual
it should work.
If neither red or green or blue are given, r.rgb could use
red=${input}.r
green=${input}.g
blue=${input}.b
That would be easy to fix.
Markus M
Description:
Keywords:
<green> and <blue>
Parse error
ERROR: parse error
grass-dev mailing list
grass-dev@lists.osgeo.org
On Tue, Mar 22, 2016 at 5:37 PM, Markus Metz <markus.metz.giswork@gmail.com>
it should work.
red=${input}.r
green=${input}.g
blue=${input}.b
I thought we tried to remove this type of default parameters from most of
the modules (with the exception of import/export). Perhaps not.
On Tue, Mar 22, 2016 at 10:37 PM, Markus Metz
it should work.
red=${input}.r
green=${input}.g
blue=${input}.b
Yes, this would exactly be the user's expectation (at least mine as a
user) who has even read the manual
markusN
> it should work.
> red=${input}.r
> green=${input}.g
> blue=${input}.b
I though you expected that the names are not generated inside the module
since you changed the manual according to my commit (r68072) and backported
both commits.
I like the current state. Perhaps not so convenient when advanced users
work in the command line but in all other cases it requires you to be
explicit, thus better for beginners (who don't have to guess the new name)
and the GUI (wxGUI can automatically show the new maps only when they are
specified in the command line).
https://trac.osgeo.org/grass/changeset/68108
https://trac.osgeo.org/grass/changeset/68077
> it should work.
> red=${input}.r
> green=${input}.g
> blue=${input}.b
both commits.
Yes, to get rid of this behaviour:
Parse error
ERROR: parse error
Still the requirement to write 3 times almost the same output name is not ideal.
I like the current state. Perhaps not so convenient when advanced users work
in the command line but in all other cases it requires you to be explicit,
thus better for beginners (who don't have to guess the new name) and the GUI
(wxGUI can automatically show the new maps only when they are specified in
the command line).
I see. Too bad that I also like the command line
