I have a shell script which writes a R script to file and then runs it. The R script includes some calls to GRASS functions using the execGRASS function from the spgrass6 package. This all works fine except when I make a call to the GRASS function r.random. It will run, but at the end of the script, the script will start from the beginning… and this will continue till using ctrl+c. This is in GRASS 7.0 on Ubuntu 12.10. In GRASS6.4 the same problem does not happen.
A simplified example of my script is below:
#!/bin/sh
LOGDIR=“$HOME”
LOGFILE=“$LOGDIR/r_model_eval.log”
echo “r.model.edm :” >> “$LOGFILE”
writeScript1(){
cat > $1 << “EOF”
options(echo = TRUE)
require(spgrass6)
execGRASS(“r.random”, flags=“overwrite”, input=“pnv_900m”, n=“100”, raster_output=“test”)
EOF
RGRASSSCRIPT1=“g.tempfile pid=$$
writeScript1 “$RGRASSSCRIPT1”
R --no-save --no-restore --no-site-file --no-init-file < $RGRASSSCRIPT1 > $LOGFILE 2>&1
A small part of the logfile looks like:
require(spgrass6)
Loading required package: spgrass6
Loading required package: XML
GRASS GIS interface loaded with GRASS version: GRASS 7.0.svn (2013)
and location: AEA
Collecting Stats…
0% 3% 6% 9% 12% 15% 19% 22% 25% 28% 31% 34% 38% 41% 44% 47% 50% 53% 57% 60% 63% 66% 69% 73% 76% 79% 82% 85% 88% 92% 95% 98% 100%
Writing raster map …
0% 3% 6% 9% 12% 15% 18% 21% 24% 27% 30% 33% 36% 39% 42% 45% 48% 51% 54% 57% 60% 63% 66% 69% 72% 75% 78% 81% 84% 87% 90% 93% 96% 99% 100%
save.image(file=“testing.RData”)
require(spgrass6)
Collecting Stats…
etc…
As you can see, after creating the random layer, it starts the script again (line 14). It only happens, it seems, when using execGRASS to run the r.random function (or use a direct system call). Using execGRASS with any other function work fine it seems.
I am not sure this is a problem with GRASS GIS, R, or what, but let me first try the GRASS GIS email list. Any idea what could go wrong here?
Paulo
