Hi devs,
If I use a series of integer type maps as input to t.rast.series or r.series and select minimum as method, the output is a floating point map. I would have thought that if the input are integers then output should be integer as well. I realized when I made a plot of the map and got a smooth legend instead of integer numbers.
Here an example:
for i in seq 1 6
; do r.mapcalc expression=“map${i} = ${i}” ; done
r.info map1 <<-- CELL
r.series input=g.list rast pat=map* sep=,
method=minimum output=test_min
r.info test_min <<-- DCELL
Is this an expected behaviour?
best,
Vero
* Veronica Andreo <veroandreo@gmail.com> [2018-08-25 18:17:51 +0200]:
Hi devs,
Here an example:
for i in `seq 1 6` ; do r.mapcalc expression="map${i} = ${i}" ; done
r.series input=`g.list rast pat=map* sep=,` method=minimum output=test_min
Vero,
just guessing,
maybe it's similar to my question about 'count' in `r.stats.zonal` [0]:
use of DCELL allows for integers larger than CELL (32-bit).
Nikos
[0] https://lists.osgeo.org/pipermail/grass-dev/2018-August/089197.html
Hi Nikos,
El dom., 26 ago. 2018 13:16, Nikos Alexandris <nik@nikosalexandris.net> escribió:
Hi devs,
Here an example:
for i in seq 1 6
Vero,
just guessing,
maybe it’s similar to my question about ‘count’ in r.stats.zonal
[0]:
Thanks for your answer. I can understand the storage of ‘count’ output as double since the count can exceed the length of input data type. But why minimum? If I input integer data, the minimum of a set of integer numbers should be integer, no? How can it exceed the CELL range if it is the minimum of that range?
Just thinking out loud
Vero
Le Dimanche 26 août 2018, Veronica Andreo a écrit :
Hi Nikos,
> >Hi devs,
> >Here an example:
> Vero,
> just guessing,
Thanks for your answer. I can understand the storage of 'count' output as
Me too: among a long 'series' of minimums, maybe an extreme min?
Maybe a silly thought.
Nikos
The type of the output map is independent of the inputs, determined
solely by the method. The count, diversity, min_raster and max_raster
methods generate integer maps; all other methods generate
floating-point maps.
It probably wouldn't be particularly involved to add another flag to
the method table to indicate that a particular method will always
produce an integer result for integer inputs.
Also, the use of weights= forces the output to floating-point even if
the method doesn't actually support the use of weights.
Thanks for the explanation, Glynn
El mar., 28 ago. 2018 a las 11:01, Glynn Clements (<glynn@gclements.plus.com>) escribió:
It probably wouldn’t be particularly involved to add another flag to
the method doesn’t actually support the use of weights.
Sorry, I pressed send earlier than intended…
El mar., 28 ago. 2018 a las 13:45, Veronica Andreo (<veroandreo@gmail.com>) escribió:
Is this worth an enhancement ticket? I do not know how to implement any of this myself.
thanks again,
Vero
On Tue, Aug 28, 2018 at 1:49 PM Veronica Andreo <veroandreo@gmail.com> wrote:
Please try trunk r73206.
Markus M
thanks again,
Vero
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
El mié., 29 ago. 2018 a las 22:37, Markus Metz (<markus.metz.giswork@gmail.com>) escribió:
Works as expected
Thanks a million, Markus!
Vero
