On Mon, Sep 7, 2009 at 11:49 PM, Glynn Clements<glynn@gclements.plus.com> wrote:
Markus Neteler wrote:
I have an extra issue: For the particular growing degree day calculation
I am facing the problem that the values I am comparing with a FP values
and that GRASS_EPSILON is useless in this particular case. It works
only with
/* EPSILON = GRASS_EPSILON; */
EPSILON = 10.
if (fabs(tval - values[i]) < EPSILON ) {
because the pixel values are growing so quickly from one map to the
next. Since we need a generic solution, another "precision" or whatever
parameter needs to be passed otherwise the thresholding fails completely.
EPSILON however depends on the input maps and needs to be user
controllable.
How to deal with that?
What exactly are you trying to measure?
From your original post, it sounds like you have a monotonically
increasing input,
Here an example (doy = day of year; gdd = growing degree days):
"doy","gdd"
1,0.0
2,0.0
3,0.0
4,0.0
44,3.4
45,3.4
46,4.5
47,6.3
99,164.6
100,170.3
101,175.4
102,178.5
193,997.8
194,1008.4
195,1018.3
196,1026.9
363,1980.1
364,1980.1
365,1980.1
it is a kind of sigmoidal function which differs from year to year and
pixel stack to pixel stack.
and you want the time (index) at which the value
first exceeds the threshold, e.g.:
for \(i = 0; i < n; i\+\+\) \{
if \(values\[i\] >= threshold\) \{
\*result = \(DCELL\) i;
return;
Rast\_set\_d\_null\_value\(result, 1\);
If you need an approximate equality comparison, the usual solution is
to use the ratio of the difference to one of the values, e.g.:
double EPSILON = 1e\-6; /\* 1 ppm \*/
if \(fabs\(values\[i\] \- threshold\) < EPSILON \* threshold\)
The problem is the non-linear increase here, I guess: If I would check
for 1000 GDD in above example, I have the input
193,997.8
194,1008.4
but get
EPSILON = 1e-6
abs(997 - 1000) < EPSILON * 1000
[1] FALSE
abs(1008.4 - 1000) < EPSILON * 1000
[1] FALSE
and still won't find it.
