I've been posting about problems with r.sim.water. I have compiled
GRASS64 SVN with debugging symbols and set the GRASS DEBUG environment
variable to level 5. I'm also running GRASS from gdb.
I ran r.sim.water on a region with 1103886544 cells and it bombed out
quickly. The output was:
GRASS 6.4.0svn (c83a_tm_29deg_e):~ > r.sim.water --overwrite
elevin=c83a_dem_25m@PERMANENT
dxin=c83a_dem_25m_clipped_dx@rsimwater_toetse
dyin=c83a_dem_25m_clipped_dy@rsimwater_toetse
rain=rain_50@rsimwater_toetse infil=infilt_0@rsimwater_toetse
manin=manning_0.05@rsimwater_toetse
depth=depth_1mres_rain50_infil0_niter10@rsimwater_toetse
disch=disch_1mres_rain50_infil0_niter10@rsimwater_toetse
D2/5: G__read_Cell_head
D2/5: G__read_Cell_head_array
D3/5: region item: proj: 99
D3/5: region item: zone: 0
D3/5: region item: north: -3122229.69982072
D3/5: region item: south: -3155672.30728643
D3/5: region item: east: -33474.90929218
D3/5: region item: west: -66483.27873573
D3/5: region item: cols: 33008
D3/5: region item: rows: 33443
D3/5: region item: e-w resol: 1.00001119
D3/5: region item: n-s resol: 0.99998826
D3/5: region item: top: 0.5
D3/5: region item: bottom: -0.5
D3/5: region item: cols3: 33008
D3/5: region item: rows3: 33443
D3/5: region item: depths: 1
D3/5: region item: e-w resol3: 1.00001119
D3/5: region item: n-s resol3: 0.99998826
D3/5: region item: t-b resol: 1
D3/5: rain_val is set to: -999.990000
D3/5: manin_val is set to: -999.990000
D3/5: infil_val is set to: -999.990000
default nwalk=-2087194208, rwalk=2207773088.000000
Killed
Since GRASS itself doesn't exit abnormally, gdb doesn't seem to notice
that anything is wrong.
Is there anywhere else (a log file perhaps) where I can try and find
out what is going on?
Thanks
Hanlie
Hello,
IMHO your region resolution is much to large for r.sim.water:
33008x33443 cells -> 1.1 billion cells.
You can use a coarse resolution or you can split your dataset in
smaller pieces for computation.
r.sim.water loads all raster maps into your memory and creates
additionally a maximum of 7000000 walkers. I would suggest to use
about 1000000 cells for computation.
Best
Soeren
2010/9/8 Hanlie Pretorius <hanlie.pretorius@gmail.com>:
Killed
Thanks
Hanlie
grass-dev mailing list
grass-dev@lists.osgeo.org
Thanks for the reply, Soeren.
I have had similar results on rasters with fewer than 1 million cells.
The process runs for a litte longer but then also gets killed.
I made the resolution very fine on purpose because I was trying to
crash r.sim.water to get to the debugging messages. Does that make
sense?
2010/9/8, Soeren Gebbert <soerengebbert@googlemail.com>:
Hello,
Best
Soeren
Killed
Thanks
Hanlie
Hello,
sense?
Unfortunately not really. The process get killed because it tries to
allocate much to much memory and this may be not related to the
problems you face when computing with a fewer number of cells. The
debug messages will always be printed if the environmental variable
was set correctly.
Maybe using breakpoints while debugging will point to the problem?
Best
Soeren
Hello,
Best
Soeren
Killed
Thanks
Hanlie
