[GRASS-dev] r.sim.water options
I have two questions regarding r.sim.water.
First, what are “walkers”. How does the nwalk parameter affect the analysis? It seems that with a region larger than a few million cells, the module fails, regardless of the nwalk parameter. (I have a region of just over 8 M cells, and even with nwalk=1, it fails with ERROR: nwalk (7000001) > maxw (7000000)! )
But when I reduce the region to < 7M cells then the nwalk parameter helps, and the analysis succeeds.
Next (asked on the grass-user list, but no response yet):
Is there a way to create a surface flow model where the rainfall stops after a specified time, and the model continues to run, and creates depth and discharge rasters after the actual rainfall has stopped?
i.e. in the case of a short thunderstorm, I want to try to predict the extent of a flash flood that rises, then subsides some time after the rain has ended.
Micha
Micha Silver
[http://www.surfaces.co.il/](http://www.surfaces.co.il/)
Arava Development Co.  +972-52-3665918
