Hi devs,
does the default `percentiles=50` in `r.stats.quantile` equal to the median?
Is the definition exclusive or inclusive?
Thank you for any insight, Nikos
See also
- https://en.wikipedia.org/wiki/Percentile
- https://math.stackexchange.com/q/2048470/445399
On Fri, Jan 22, 2021 at 2:51 PM <nik@nikosalexandris.net> wrote:
Hi devs,
does the default percentiles=50
in r.stats.quantile
equal to the
median?
The median is commonly defined as the 50% percentile, the “middle” item of a sorted dataset. See
https://en.wikipedia.org/wiki/Median
In GRASS, calculations of the median and the 50% percentile are identical.
HTH,
Markus M
See also
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
Thank you Markus!
Hi devs,
in r.stats.quantile
equal to the
median?
HTH,
Markus M
See also
