I had some trouble with r.stream.basins which labeled all basins created with points option as -1.
After some investigation I found out that the problem was that my vector points map only had categories on layer 2.
After transferring the categories to layer 1 everything worked fine. During my test with NC dataset I also saw that if there only some points on a layer have a category, no basin is produced for the points without category; even if the message of the module says differently.
The latter can be reproduced with NC data like this:
g.region -p raster=elev_lid792_1m
r.watershed elevation=elev_lid792_1m accumulation=flow_accum drainage=draindir
echo "638867.632469|220039.545432|7
638563.344273|220045.597694|12
638945.422741|220706.456664|999
638978.525142|220455.417819|" | v.in.ascii input=- output=points columns=“cat integer” cat=3 --o
r.stream.basins --o --v -c direction=draindir points=points memory=3000 basins=basins
From that experience I would like to suggest either
a) Adding a layer option to the module
b) Give at least a warning if features in the vector map are lacking a category
c) Clarify the behavior in the manual
or maybe a combination of a-c…
I could assist with c)…
What do you think?
Stefan
On Thu, Dec 29, 2016 at 11:07 AM, Blumentrath, Stefan <Stefan.Blumentrath@nina.no> wrote:
If a module accepts a vector as input, there should (if feasible) also be the options layer, cats, where in order to optionally select a subset of vector features. Can you please add a ticket for r.stream.basins that these options need to be added, with layer=-1 meaning that basins must be created for all points, even if they have no category value? Thanks!
Markus M
What do you think?
Stefan
grass-dev mailing list
grass-dev@lists.osgeo.org
