[GRASS-dev] r.stream: Incompatible library version for module.
I just recompiled grass7 and installed r.stream modules by g.extension. But when i try to use them I get error:
GRASS 7.0.svn (nc_spm_08):~ > r.stream.extract
ERROR: Incompatible library version for module. You need to rebuild GRASS
or untangle multiple installations.
GRASS 7.0.svn (nc_spm_08):~ > r.stream.basins
What’s wrong?
madi
Eng. Margherita Di Leo
Ph.D. Candidate
Methods and Technologies for Environmental Monitoring
Department of Environmental Engineering and Physics (DIFA)
University of Basilicata
Campus Macchia Romana
85100 - Potenza
Office: +39-0971205360
Forgot to say: I’m on debian.
madi
On Mon, Jan 30, 2012 at 9:18 PM, Margherita Di Leo <dileomargherita@gmail.com> wrote:
What’s wrong?
madi
Ph.D. Candidate
85100 - Potenza
hi,
keep in mind there are now 2 addons-repositories for grass-addons:
http://trac.osgeo.org/grass/browser/grass-addons/grass6/raster/r.stream.extract
http://trac.osgeo.org/grass/browser/grass-addons/grass7/raster/r.stream.extract
maybe a mismatch between these 2 repositories?
Helmut
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/r-stream-Incompatible-library-version-for-module-tp4351790p4351883.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
I used g.extension so i didn't deal directly with the repository.
madi
View this message in context: http://osgeo-org.1560.n6.nabble.com/r-stream-Incompatible-library-version-for-module-tp4351790p4352036.html
What's wrong?
you need to run
make distclean
and reconfigure etc.
ciao
Markus,
What’s wrong?
you need to run
make distclean
I did it, but just to be sure, did it again, but error is still there.
madi
ciao
Ph.D. Candidate
85100 - Potenza
2012/1/31 Margherita Di Leo <dileomargherita@gmail.com>:
> GRASS
it seems that you are compiling addons with different GIS library. Are
you sure that you don't have multiple installation of GRASS on your
computer?
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
for me it works
madi
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
I recompiled grass7 again, making svn checkout instead of svn up, and solved.
madi
On Tue, Jan 31, 2012 at 10:31 AM, Luca Delucchi <lucadeluge@gmail.com> wrote:
for me it works
madi
ciao
Luca
www.lucadelu.org
Ph.D. Candidate
85100 - Potenza
