[GRASS-dev] r.sun artifacts
Hi, this is my first post and I hope someone could help me.
I'm using r.sun for computing a solarmap of the alpine arch in Friuli
Venezia Giulia (IT).
I'm using this command:
r.sun -s elevin=dem_40_fvg_wgs84 aspin=asp_fvg_wgs84 slopein=slo_fvg_wgs84
lin=1.5 alb=0.2 horizonstep=10 beam_rad=irr_fvg1 insol_time=ins_fvg1
diff_rad=diffuse_irr__fvg1 refl_rad=ground_refl_fvg1
glob_rad=total_irr_fvg1 day=1 step=0.25 dist=1.0 numpartitions=1
--overwrite
But the resultant map have a lot of artifacts (lines of pixels with wrong
values, see the attachment)
http://osgeo-org.1803224.n2.nabble.com/file/n6917645/r.sun.jpg
I've tried to delete "aspin" and "slopein" parameters and i've changed
"step" and "dist" with no results.
What can i do for remove this artifacts? Except for this problem the map is
good.
I'm using Grass6.4.1. My OS is W7 64bit.
thx
Sergio
p.s. sorry for my english
View this message in context: http://osgeo-org.1803224.n2.nabble.com/r-sun-artifacts-tp6917645p6917645.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
On Fri, Oct 21, 2011 at 7:08 PM, Sergio Gollino <gollinosergio@gmail.com> wrote:
Welcome here!
try to avoid aspin= and slopein= since r.sun can also calculate
those internally.
--overwrite
... this part looks ok.
Mhh. So please check the DEM then bu calculating a shaded map with
r.shaded.relief. Perhaps the artifacts are therein?
I had no such problems in a close-by area with the same version (but Linux
which should not matter here).
Thx for your reply. As you sad, the problem was in the DEM (but I don't know
why).
I created a new mapset (equal than the old) and I reprojected the DEM (with
r.proj) again. So, now, there aren't any artifacts. The map it's all good.
Thank you!
Sergio Gollino
View this message in context: http://osgeo-org.1803224.n2.nabble.com/r-sun-artifacts-tp6917645p6924173.html
