[GRASS-dev] r.surf.contour MASKs
re. r43805:
+<p>
+An existing MASK raster map is respected for both reading <em>input</em>
+and writing <em>output</em>.
is that a newly added feature or documenting an old one?
if new, does it help speed up the very slow searches where there
is no input data? (e.g. when the region contains a large lake or
partial ocean, where there are no contour lines)
cheers,
Hamish
Hamish wrote:
re. r43805:
+<p>
An old one (absent in grass 3.2, introduced in grass 4.0), but it was
not working properly in grass6 because of missing NULL support, unless
a MASK used zero and not NULL for masking.
Yes, it does help speed up (now that NULL cells in a MASK are skipped
as intended).
Apart from floating point support, I have not added any new features
to r.surf.contour.
Markus M
