[GRASS-dev] r.surf.fractal [was: v.buffer]
Hamish ha scritto:
> in devbr6 and relbr6_4 I have added backwards compatibility aliases
> for the removed options. so all should be ok again.
Paolo wrote:
Thanks for this.
Same thing happens for r.surf.fractal (option d=float has been changed
in option dimension=float). Could this also be fixed?
it shouldn't need to be. the parser will accept shortened names as long
as they do not conflict. Therefore a call to 'r.surf.fractal d=' will
work the same in grass 6.3 as it will in 6.4.
So names can be lengthened without worry.
Does it not work??
More generally: is there a list of changed options, so we
can try and fix them all?
I don't know of an automatic way of testing for that, but there should
not be any.
maybe r.terraflow's STREAM_DIR option?, but we should fix whatever the
new caps option bug is in the parser and leave that in caps for 6.x.
Hamish
Does it not work??
It does not, at least through the QGIS plugin.
All the best.
