Hamish ha scritto:
> no? what is the exact error message?
Paolo:
option d not recognized
Using grep I can not find any trace of that message in the latest qgis
trunk/ SVN or GRASS's libgis. Has it been retranslated?
does QGIS's grass toolbox double-check the module options using the 'g.module --interface-description' or does it just try to run what the programmer/user threw at it and see what happens?
Hamish
(I have cc'd grass-dev ML in the bug ticket to avoid all this cross posting)
Sorry, it may be slightly different: I do not have a qgis1.x+grass64
machine at hand now, so I cannot check.
Dunno. When a module is called, if an option is not present, it throws
an error, so it seems the first of the two options.
Thanks.
