If you need a faster module for computing shortest paths , I have uploaded a module called r.terracost in grass-addons.
It runs Dijkstra algorithm, which is the standard algorithm for SP (all costs need to be non-negative). The user specifies the input and output grid, the grid of start points, and the number of tiles. If you give it numtiles=1, it runs the entire computation in memory. If numtiles>1, it switches to an external version, where it computes on one tile at a time. This is efficient in the case the grid is large and does not fit in memory. To find the suggested number of tiles, runt it with flag -i.
hope this is useful
-Laura
