Laura Toma wrote:
The problem is that it attempts to set the memory manager limit to 0
(see below: limit=0B), and the first line in
MM_register::set_memory_limit(size_t new_limit)
is
assert(new_limit>0).
Therefore the problem.
So the question is, why does it try to set the memory limit to 0?
Unless the user specifies a value, the default value is 300MB, see
main.cc:
mem->answer="300";
opt->mem = atoi(mem->answer);
size_t mm_size = opt->mem << 20; /* opt->mem is in MB */
MM_manager.set_memory_limit(mm_size);
It doesn't even get as far as main(), let alone parsing and using the
mem= option:
$ gdb r.terraflow
Program received signal SIGABRT, Aborted.
[Switching to Thread 0xb6bcf9a0 (LWP 668)]
0xb7fd4424 in __kernel_vsyscall ()
where
#0 0xb7fd4424 in __kernel_vsyscall ()
#1 0xb7d42311 in *__GI_raise (sig=6)
at ../nptl/sysdeps/unix/sysv/linux/raise.c:64
#2 0xb7d43bf8 in *__GI_abort () at abort.c:88
#3 0xb7d3b6df in *__GI___assert_fail (
assertion=0x6 <Address 0x6 out of bounds>,
file=0x6 <Address 0x6 out of bounds>, line=6,
function=0x80e3985 "void* operator new(size_t)") at assert.c:78
#4 0x080c8985 in operator new (sz=24) at mm.cc:344
#5 0xb6ec7c2f in global constructors keyed to _ZN4geos7ProfileC2ESs ()
at ../util/Profiler.cpp:20
#6 0xb6ec8165 in __do_global_ctors_aux () from /usr/lib/libgeos.so.2
#7 0xb6e3a3c9 in _init () from /usr/lib/libgeos.so.2
#8 0xb7fe3a77 in call_init (l=0xb6ef3108, argc=2, argv=0xbfead4c4,
env=0xbfead4d0) at dl-init.c:70
#9 0xb7fe3b16 in _dl_init (main_map=0xb7ff2658, argc=2, argv=0xbfead4c4,
env=0xbfead4d0) at dl-init.c:134
#10 0xb7fd59df in _dl_start_user () from /lib/ld-linux.so.2
The assert is triggering in the constructor for a static variable
within the GEOS library (linked in by GDAL).
geos-2.2.3/source/util/Profiler.cpp has:
static Profiler *internal_profiler = new Profiler();
This gets called before main(), but the customised "operator new()" in
lib/iostream doesn't work until the memory manager has been
initialised, which doesn't occur until G_parser() has been called.
