[GRASS-dev] R.terraflow crashing on Mac
I tried to run r.terrraflow on my Mac Intel last night and it crashed. This is a version I compiled from the cvs on 23 January. Other recent versions seem to work fine on the FC6 and FC4 workstations in my lab. I’m copying the error below in case anyone has a clue. (FWIW, the warning about elevation_dem being found in multiple mapsets is both annoying and misleading as my working mapset was indeed PERMANENT. This now happens with multiple modules and I don’t remember it appearing as often before).
Michael
========= r.terraflow error ====================
r.terraflow elev=elevation_dem filled=rterraflow_filled direction=rterraflow_direction swatershed=rterraflow_swatershed accumulation=rterraflow_accum tci=rterraflow_tci d8cut=infinity memory=1000 STREAM_DIR=/var/tmp stats=stats.out --overwrite
‘cell/elevation_dem’ was found in more mapsets (also found in
PERMANENT).
elevation stored as FLOAT (4B)
raster elevation_dem is of type CELL_TYPE --you should use
r.terraflow.short
region size is 93 x 143
STREAM temporary files in /var/tmp (THESE INTERMEDIATE STREAMS
WILL NOT BE
DELETED IN CASE OF ABNORMAL TERMINATION OF THE PROGRAM. TO SAVE
SPACE PLEASE
DELETE THESE FILES MANUALLY!)
file stats.out exists - renaming.
MFD flow direction
D8CUT=999999986991104.000000
memory size: 1000.00M (1048576000) bytes
Memory manager registering memory in MM_IGNORE_MEMORY_EXCEEDED mode.
PERMANENT).
total elements=13299, nodata elements=0
largest temporary files:
FILL: 727.29K (744744) [13299 elements, 56B each]
FLOW: 1.01M (1063920) [13299 elements, 80B each]
Will need at least 2.03M (2127840) space available in /var/tmp
COMPUTING FLOW DIRECTIONS
classifying nodata (inner & boundary)
r.terraflow(9913) malloc: *** Deallocation of a pointer not malloced:
0x23aff8; This could be a double free(), or free() called with the
middle of
an allocated block; Try setting environment variable MallocHelp to
see tools
to help debug
delete: MM_manager.register_deallocation failed
/Users/cmbarton/grass_dev/grass6/macosx/GRASS/…/…/raster/
r.terraflow/IOStr
eam/lib/src/mm.cc:359: failed assertion `0’
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
