Can someone test the attached patch on Windows (MSys)?
It eliminates various Unix-isms, specfically, it provides workarounds
for the following functions::
getpagesize
getrlimit
getrusage
gettimeofday
mkstemp
random
sbrk
unlink
It also fixes a call to putenv(), but that needs to be fixed on Unix
as well. putenv() isn't guaranteed to copy the string; in fact, POSIX
says that it shouldn't be copied. This means that passing an automatic
variable is incorrect.
According to the Linux manpage, glibc 2.1.2 and later conforms to
POSIX, while earlier versions copy the string (as does the BSD
version).
(attachments)
r.terraflow-windows.patch (4.9 KB)
I now get:
main.cc: In function `void record_args(int, char**)':
main.cc:327: error: `ctime_r' undeclared (first use this function)
Looking at mingw's time.h, I can confirm that there is no declaration for
ctime_r.
Moritz
I now get:
The attached patch should fix that issue.
If there are any remaining errors, please use "make -k", so that you
get all of them.
(attachments)
r.terraflow-windows.2.patch (409 Bytes)
I now get:
get all of them.
Log attached.
Moritz
(attachments)
r.terraflow.make.log.gz (790 Bytes)
>> I now get:
> get all of them.
Log attached.
The attached patch supersedes both previous patches, and should be
applied to the stock SVN source (either revert the previous patches
with "patch -R ...", or use "svn revert").
(attachments)
r.terraflow-windows.3.patch (6.93 KB)
Compiles fine on MinGW/MSYS with an SVN checkout from an hour
ago. Can start the module and get help text. Don't know how to
use it so can't really test any further.
Best,
Benjamin
I now get:
get all of them.
Log attached.
grass-dev mailing list
grass-dev@lists.osgeo.org
Benjamin Ducke
Senior Applications Support and Development Officer
Oxford Archaeological Unit Limited
Janus House
Osney Mead
OX2 0ES
Oxford, U.K.
Tel.: ++44 (0)1865 263 800
benjamin.ducke@oxfordarch.co.uk
Committed.
