On my Ubuntu 16.04 box I get the following error message in GRASS 7.4.1 (package install from UbuntuGIS) with r.tileset:
r.tileset sourceproj=+init=epsg:25833 maxrows=10000 maxcols=10000 | wc -l
ERROR: cs2cs program not found, install PROJ.4 first:
http://proj.maptools.org
ERROR: cs2cs failed
0
And locate tells me that there indeed is no cs2cs on my PATH/system…
Is that related to the move to Proj.5?
Can GRASS even be installed without Proj?
Is that a GRASS issue, a packaging issue or simply an installation issue?
r.tileset should probably be updated to use cct https://proj4.org/development/migration.html (yet, I cannot find cct on my system either)…
Stefan
On Fri, Sep 21, 2018 at 3:44 PM Stefan Blumentrath <Stefan.Blumentrath@nina.no> wrote:
ERROR: cs2cs failed
0
No, it needs libproj. However, this provides only the libraries, for cs2cs / cct you also need proj-bin (on Debian-based systems).
Yes, r.tileset should use cct if available, otherwise cs2cs.
Can you please open a ticket for this issue?
Markus M
Thanks for the info.
Maybe the grass-core package on Debian should suggest installing also proj-bin (maybe it does and I just overlooked)?
Ticket opened for cct-support here: https://trac.osgeo.org/grass/ticket/3653
ERROR: cs2cs failed
0
Markus M
